Question about Refrigerators
Refrigerator is freezing food - Refrigerators
  • 10,865 Answers
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Jul 11, 2009
    PSC23NSTESS FREEZING VEGTABLES
    Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
    • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
    • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
    • The fresh food control should be at the normal setting of 5.
    Freezer on Top Models
    First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
    • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
    • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
    Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
    Food is freezing in refrigerator
    There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
    Refrigerator is Too Cold and Freezing Food
    heatman101
    Feb 14, 2011 | Maytag Refrigerators
    The fridgerator keep freezing the food. it is on the lowest setting but still it freezed the food. whirlpool MODEL: ET18NMXAW03 SERIAL: ED3042768 have had someone tell me to clear the food so that it...
    heatman101
    Jan 25, 2011 | Whirlpool Refrigerators
    Suddenly the refrigerator is freezing everything we have not changed the settings we tried to even turn down and is still freezing the food.Help!
    heatman101
    Jan 04, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    Kitchenaid side by side freezes food in the refrigerator side
    The damper between fridge and freezer is most likely stuck open.
    Oct 02, 2017 | KitchenAid (KSRD22FKST) Side by Side...
    Jenn Aire refrigerator keeps freezing food.
    Your thermostat is faulty, pure and simple.
    If the thermostat fails to do it's job, your compressor continues to run thus freezing your produce.
    Feb 02, 2009 | Jenn-Air JCB2280HES Side by Side...
    Refrigerators Logo
    335 people viewed this question
    Top Refrigerators Experts
    Marvin
    Marvin
    Gil Shultz
