Question about Ovens
I´m having a problem with my wall oven FRIDIDAIRE FEB789WCCG. The front control module where the clock and buttons are have no power, its completely blank. when I push on the buttons nothing happens. however, when I open the oven door, the light comes on. so it is getting power, and we checked the power to ensure there's 220v coming in which it is. I reset the breakers also, and yet the control panel is still blank, no clock, nothing. I'm thinking it could be a fuse for control panel on the oven, but I don't know where its located or what it looks like. any ideas? rafaponte@hotmail.com
  • 132 Answers
If you can reach inside the oven the fuse almost beside the power terminals usually like cylinderical shape and it has nominal values wroted on it , must be checked continuity at 1st by ohmmeter
thanks
Posted on Jul 11, 2009
I have a white frididaire oven model # FEF316B5D was cooking pizza then blew breaakers and now it is completly dead. Breaker is on but now power from oven
sounds like your bake element element has failed. Parts are readily available on line or call for service
May 27, 2018 | Ovens
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
Hi i have a blanco electric oven model no bms 901 sse and the timer shows A and no time . And the oven does not work can u please help me
I had a similar problem with the same model of Blanco Oven but in my case the clock was completely dead apart from the letter A which was lit (and this proved there was power to the oven).
The oven would not work because the clock module (electronics control unit) was dead.
I rang a Blanco parts supplier, who advised the clock module was no longer available (Blanco advised the same). Another supplier said they could supply the clock module for A$425 which is an absolute ripp off (a reasonable price would be A$50 as it only has a couple of components).
As the clock module is not essential (it only provides the time, alarms, and fancy features most people don't need) I decided to by-pass it by shorting out the two (brown) wires on the LHS (which connect to the relay on the clock module). In effect it behaves as if the relay is always ON, supplying power to the stove.
The oven now gets power and works fine and it cost me virtually nothing to repair. I strongly recommend this solution to anyone experiencing problems with the clock module.
Some basic understanding of electrical/electronics systems is all that is needed to implement this repair.
Aug 10, 2011 | Ovens
We have a Frigidaire Wall Oven that shows Err F3 - no buttons work. Model FSC88B-4 . The Oven temperature sensor measures at 1089 Ohms. There is 5 VDC on the control board. Tried resetting by removing the...
The sensor checks good. The only thing left to check the wiring between the control and the sensor. Check this for opens and shorts. If all checks good you will need to replace the EOC electronis oven control / clock. You can get diagrams and illustrations at www.appliancehelponline.com by entering your model #. All parts come with installation instructions.
Apr 15, 2010 | GE 24" Built-in Single Electric Wall Oven...
The digital control display is extremely dim
your model should be a jjw9527AAW.... usually when that clock assembly goes dim u must replace that clock ... for your model it is a part number #71003424.. that clock on sears.com is for sale at $186.06.. call around or shop around for a bettter price remeber shipping charges through sears though and prob take longer to get ahh nevermind ur call...ohh yea kill the power before servicing or call for service... hope this helps take care
Jan 28, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Built-In Oven Buttons Stop Working
It is the whole front face w/ the buttons. My whole neigborhood has these ovens (same builder, same ovens) and this part lasts about 2-4 years. The part is about $165. You can see it on Home Depot's appliance repair site. It looks like there is nothing electronic, but there is, and it's busted. It is really easy to replace:
1. Turn off the breaker at your house's breaker panel.
2. Verify there is no power to the oven.
3. Open the oven door. Look on the right and left side of the oven. There should be 4-6 screws going from vertical trim pieces of the oven into your cabinets. Your builder may have also put screws from the bottom trim of the oven into your cabinets. Mine did not. Remove these screws.
4. After that, your oven should slide forward out of the cabinet. Pull it about 6 inches out.
5. There are two screws (1/4 inch hex headed screws) holding the front panel to the oven. Remove those.
6.Slide the front panel off.
7. Remove the computer ribbon looking wire from the back of the control panel. It's a strange connection - it should come out effortlessly when done right. The little grey connection that surrounds the wire's entry point stays on the panel, but a wedge is jammed between the grey surround and the wire. You pull the wedge out and the wire comes out...easier than my credit card out of my wallet.
8. Remove the four screws (again, 1/4 inch hex headed screws) connecting the thick, double layered circuit board and clock display from the metal face.
9. The metal face is what you need to replace. Pasted onto the front of the metal face is a super thin button panel, and that's the part that died, and will die again, and again, and again...
Email me for some pictures:
schmidtkeith1@yahoo.com
Aug 02, 2009 | Maytag 30" Built-In Single Electric Wall...
-F9- Clean Frididaire Gallery Series
F9 code means Control has detected a problem with the motor door latch assembly Soultion: Check wiring, replace the motor door latch assembly if necessary
May 06, 2009 | Frigidaire 30 in. Electric Gallery Series...
Double GE wall oven - F7 code
from repairclinic.com:
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
Apr 27, 2009 | GE Ovens
Oven digital lighted display is dim
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Dacor ECS230 Wall Oven Control Panel Time functions not working
Try turning the power off at the breaker for 12 hours.
I had the same problem, tried turning the power off for a few minutes but that did not fix the problem.
Leaving the power off overnight seems to have fixed it.
Nov 09, 2007 | Dacor Millennia MOV130 Electric Single...
Ovens Logo
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
