AC fan not working
I had a 3 1/2 ton split unit Intertherm. Not sure of the model number. The outside fan is not working. I hear a humming noise and the unit is warm to the touch. I turned the unit off and waited 5 minutes then turned it back on and the ac worked and the fan was running. After about 5 minutes it stopped again and is making a squealing noise. Any advice before calling a repair man??
    President:
  • 1,124 Answers
Dont run it until the problem is fixed..
The humming is the compressor.. With out the fan - it will get damaged..
The first thing I would try is replace the capacitor.. Be sure power is off !!
This scenario is tipical of the capacitor..
Its metal & looks kinda like a can & has 3 wire conections at the top..
Be careful to not mix up the wire sequence..
Change one wire at a time and be sure..
Also - you mentioned sweeking.. Its also possable that the fan motor is failing..
But a copasitor is cheeper than a fan motor - and makes the most sense to replace..
Hope this helps !!
Please rate me good ;o)
Posted on Jul 11, 2009
    Sergeant:
  • 340 Answers
Turn it off call repairman
  • taa43 Jul 12, 2009
    good luck finding a capacitor if you don't know what your doing U could get hurt save your self get a service tec some things left best to experts. turn off the power before U do anything. Tom
How may capacitors are there in LG split ac 1.5 ton unit
At least 3. 1 on the inside unit fan, 1 on the outside unit fan and 1 on the compressor. The outside unit may have both in a single chassis.
Aug 15, 2016 | LG Electronic Window Air Conditioner
Why is my Intertherm P681S unit getting hot and the fan is is stopping?
Is the outside running? Is the outside fan running? Probably what is happening the fan outside quits running and the compressor gets hot and goes into thermal overload. need to check to make sure the outside fan is running.
Aug 30, 2014 | Heating & Cooling
I have an Intertherm S3BA-048KA Split AC system which has stopped blowing cold air. Indoor blower is working fine. Outdoor fan is not working. I have reset breakers (indoor/outdoor) without success. I...
First thing I would look at is to make sure you have power at the disconnect 110 coming
in on each leg to unit. Second, I would look at the capacitor for obvious bulging or leaking
Third I would check to see if the contactor has burnt points or bugs in it. Your disconnect
may have fuses in it which may have failed as well .
(All checks of the unit with power off to all breakers as there will be more than one
double breaker supplying power to the unit).
The hum you hear indicates that the contactor is pulled in on the outside unit but still may
be burnt or have ants or earwigs especially in between the contacts
. The capacitor can hold a charge even after equipment is off so discharge it to the chassis
before removal. Replace only with same Microfarad rating and equal voltage or higher
Remember to mark the wires as to which came off the HERM / C/ FAN terminals or take a
cell phone picture.
I have just replaced my intertherm condensing unit after it had it's 3rd compressor failure.
It was more cost effective than buying a compressor and hoping all the other components
were going to last.
Feb 26, 2011 | Heating & Cooling
Fan not working on outside AC unit
The buzzing noise is probably the fan motor. Is the compressor running? First make sure that there are no tripped breakers. After that kill the power and check the capacitor with a multimeter. If that checks good then check the fan motor windings with the multimeter. Let me know if you have any questions.
May 26, 2010 | Intertherm P3RA-060K Air Conditioner
No AC from older Intertherm split system
It sounds like you are low on refridgerant. Double check to make sure both fans and the compressor are running. If so then you have a refridgerant problem.
Aug 29, 2009 | Heating & Cooling
Unit is running, but is no longer cooling. Fan is blowing, but air is not chilled (or cold). Unit has been running fine until a couple days ago. It has been turned off for the last 12 hours and tried...
not sure if it is a package system or a split but this is what you do.go outside where your outdoor machine is, after it has been shut off for awhile, and you should hear 2 distinct noises.1 is the outdoor fan, you should see it spinning.the other is a comppressor hum.some compressors have noise bags on them so listen closely thru the fan noise.if you hear no hum listen for a hum about every 2 to 5 minutes.if you hear this hum every so often, chances are you compressor is seized or stuck.the only thing to do there is get a tech and try a big boost to get it going.
Aug 07, 2009 | Fedders A6P09S2A Air Conditioner
Goodman 3 ton outside unit fan not blowing
Motor, wiring and/or capacitor. If the sticker on the side of the motor isn't burned off you can get the motor info off that. Model numbers from the motor do little for locating the motor but my help. Best thing to do is get the AC motor specs and look up online (cheapest) or go to a motor shop. The specs you need would be as follows.
Horsepower-Such as 1/4 or 1/3
Voltage-Most likely 240/1 (240vac single phase)
Rotation-CW/CCW looking at the shaft end of the motor
Amps
Frame size
Jul 10, 2009 | Goodman CKL60AR60 Air Conditioner
Fan will not work on outside unit.
Check the voltage to the contactor coil, it will do that if the voltage is low. This is the 24 volt part.
May 17, 2009 | Intertherm P3RA-060K Air Conditioner
We installed a 4 ton downflow coleman air handler with evap coil Model number 1854s2m we did not change out the outside unit. the outside unit is a 13 year old 3 1/2 ton intertherm condenser the system is...
you have a missmatched system, for it to work try removing the orfice on the high side txv it is not allowing the evaperator coil to fill with refrigerant properly coleman and intertherm dont like each other since they control a large market in the manufactured housing heating and cooling units electricaly connecting the componets together no issue prefromance sometimes is the issue hope this helps
May 06, 2008 | Heating & Cooling
Heating & Cooling Logo
207 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
