Question about Cariboo Cranium Game
Wiring diagram for starter alternator and battery peugeot 206 1.4 hdi . live return from alternator going straight to earth
Peugeot 206 heater resistor power wires
check each wire with a volt meter the live wire will be the positive on a negative to earth system.
Oct 20, 2014 | Cars & Trucks
My automatic headlights won't turn off on my peugeot 206 2.0 hdi (2001) any idea's?
yes put key inignition turn to first turn at the end of the indicator stalk there is a button press and hold in until it displays and makes beeping sound same scenario to turn back on
Mar 17, 2013 | Peugeot 206 Cars & Trucks
Hi, i have a x reg peugeot 206 hdi, the serpentine belt snapped, i have a new 1 but cannot find a diagram on how to fit it. please help.....i need my car!!
Peugeot 206 1.4 HDi - DV4TD (8HZ) 2004 ...
1. The serpentine belt routing diagram - without A/C (Air Conditioning)
2. The serpentine belt routing diagram - with A/C (Air Conditioning)
Sep 18, 2011 | Peugeot 405 Cars & Trucks
PEUGEOT 206 HDI STARTING PROBLEM
your ecu monitor.. emissions control unit mod is done! i dont think this is a cheap fix. either wait for warmer weather,, sell the car or find a dealer to fix this diesel puppy...word of advice .. dont buy peugeot in this country .. or any country...joke.!!
Feb 26, 2010 | 1989 Peugeot 405
Peugeot 206 1.4 hdi has developed a fault where the engine will not start.After leaving the car rest for a couple of hours it will not start .I have to manually bleed the system and the car will start and...
expensive to repair properly,quick fix??? fit two non return valves ,one in the feed and one in the return to the injector pump ,weither conventional pump or common rail pump .this will cure your problem and its cheap to do ,two valves (observe direction) in the lines .works every time on any diesel engine weither its plant or road use
Oct 18, 2009 | 2005 Peugeot 405
Need diagram for serpentine belt on peugeot expert 2ltr hdi
Hi i have a 206 1.9 D 2001 The power steering has stopped working and the battery light has come on.
what could this be
many thanks
Sep 17, 2009 | 2006 Peugeot 505
Wiring problem
peugeot complicated their wiring alternately how old is the 206 if it is early then u need to connect both lives to permanent live on car if it is a late 206 then switch the lives
Oct 12, 2008 | Car Audio & Video
Cariboo Cranium  Game Logo
519 people viewed this question
Top Cariboo Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Cariboo Toy Expert? Answer questions, earn points and help others
