Question about RIM BlackBerry Pearl 8100
There is something wrong with my blackberry pearl speakers.
When i call someone or they call me they can hear me talkingg but i can't hear them UNLESS i put it on speaker.
i know the speakers aren't broken because i can still listen to my ringtones everything.
does anyone know how i can fix it?
without buyingg thingss and downloading stuff
or is that the ONLYY optionn.?
natas123
  • 46 Answers
SOURCE: blackberry pearl
Problem After typing an incorrect password ten times and restarting the BlackBerry smartphone, JVM error 513 appears.
Cause All the data and applications have been deleted on the BlackBerry smartphone.
Resolution Reinstall the BlackBerry® Device Software on the BlackBerry smartphone and restore the data from a backup file (if available).
Link to the software download site of blackberry
https://www.blackberry.com/Downloads/entry.do?code=A8BAA56554F96369AB93E4F3BB068C22
Posted on Feb 10, 2008
SOURCE: Bluetooth for Blackberry Pearl!!!!
I use to get that messege because my phone didnt have enought memory for the transfer. I bought the memory card so now it's fine.
Posted on May 09, 2008
SOURCE: blackberry pearl 8100 doesn't ring
i had this same problem as well. the first time i did a battery pull and everything was fine again, for about an hour. when i did the battery pull again, it worked but i noticed when i was closing the door on the back that the sound stopped again. i discovered that pressing on the battery made the speaker engage again. i folded up a piece of masking tape and put it on top of the battery and then squeezed the door down to keep a constant pressure on the battery.
this isn't the classiest of fixes, but my phone rings when people call so i'll take it.
Posted on Sep 24, 2008
SOURCE: Cannot Hear people talking unless on speakerphone
I to faced the same problem.
First of all disable bluetooth in the phone and switch off the bluetooth device.
Now try to make a call and see whether you can hear it or not.
If you are unable to hear then try to press the Mute button (which is on the top of the phone).
I hope you should be able to hear the voice now.
It worked for me.
Posted on Sep 29, 2008
SOURCE: new ringtone for my text messages!
select options --> select profiles --> select advanced --> select SMS --> menu --> change options --> select the desired ringtone
Posted on May 23, 2009
Don't know why I call someone, they can hear me, but I cna't hear them unless put in a speaker or using the headset, please advise.
Hi, it seems your phone has a faulty earpiece, it's an internal component that should be replaced by a technical service center that supports your phone manufacturer.
Nov 16, 2014 | Samsung GALAXY S4
One speaker won't play very loud unless I push down on the faceplate and every now and then it will play correctly
Well, this could be a broken solder joint. Take it to someone who knows how to solder.
Aug 09, 2014 | Audio Players & Recorders
Cant hear incoming voices unless i put it on speaker. Can hear rings and all phone bells and whistles though. just not earpiece volume for incoming calls unless on speaker
this sounds like a broken earpiece speaker you might be able to find a replacement one on-line and replace it or if its still under warranty send it back in and get it replaced
Sep 25, 2009 | Motorola Mobility RAZR V3
I cannot hear the other party unless I have speaker phone on. Can this be fixed?
phone contains two speakers, loud at back and normal in front, it looks like your front speaker got broken, put it to service
Jul 11, 2009 | Pantech Matrix Cell Phone
Volume control
the ear piece may be dead or if its a flip phone check the flex cable
Nov 29, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Cant hear when someone calls me
I have A Blackberry Pearl I can only hear if I use the head set or speaker any solutions the phone hasn't been dropped, I have taken the battery out and put it back in still cant hear unless I use handset or speaker
Jun 18, 2008 | RIM BlackBerry Pearl 8100
Can't hear anything on my 9400 unless i put speaker phone on
You have a bad speaker. Problem is you can't replace just the speaker. The only solution is to replace the entire phone at your service provider
Mar 05, 2008 | LG VX9400 Cellular Phone
Problem with heaing incoming and outgoing calls unless using speakerphone
I can't hear people that call me unless I put them on speaker phone. Called Motorola and they had me reset the phone but that did nothing. Any other suggestions?
Thanks.
May 30, 2007 | Motorola Mobility RAZR V3
RIM BlackBerry  Pearl  8100 Logo
97 people viewed this question
Top RIM Computers & Internet Experts
Otman Lahlou
Otman Lahlou
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
