Rank: Wiz
Rating: 79%, 33 votes
You need to access the router setup screen if you want to do port forwarding on the router. also you need to check the IP address of the unit, or device you want to forward as well as the port service.
in accessing the router setup screen;
> open IE, on the address bar type 192.168.1.1 - username is blank and password is admin in lowercase.
> go to applications and gaming
> look for port range forwarding, input the name- any name will do
> the service port for example it is only one port service to open and that is port 80 and then you should have to put there 80 to 80 then check if tcp/udp protocol as well, check the IP address of the computer and then enable.
> to check the IP address of the computer go to start> run > cmd and hit okay > then type ipconfig check the IP address after.
hope
Comments:
Jul 13, 2009
- You need to access the router setup screen if you want to do port forwarding on the router. also you need to check the IP address of the unit, or device you want to forward as well as the port service.
hope this
