Question about Broan-NuTone Broan Range Hoods Deluxe 89000 - 39'' Range Hood - 8939
Lighs I have the Boan model 89000-a and the exhaust does work fine but the lights stopped working. Any suggestions either in getting parts or what to look for?
  • 833 Answers
Re: Lighs
Saint...first...have a look at the bulbs. Make sure the bulbs are 'really' good and that the sockets are clean inside and undamaged. Second, the switch might be bad.
Posted on Dec 11, 2007
Re: Lighs
The bulbs are fine and the sockets are clean. How do I go about changing the switch?
Posted on Jan 05, 2008
0 characters
3 Points
Ge zv850 vent hood
was this a d.i.y. project, if so was a proper ground ran from breaker usually a size bigger than the power. when the fan goes out does the light do the same, as u may have crossed your device wires. electrical can be tricky because there can be several reasons for your issue. u suggest u double check your work ensuring everything is
Feb 17, 2014 | Range Hoods
Exhaust fan just installed not working
Did you have it professionally installed? I would suggest contacting the manufacturer to see if the issue is under warranty. You can find the support page here:
Dec 23, 2013 | LG Studio Series LSVC302ST
Stopped working after power outage
If you cannot fix - too expensive or whatever - consider a replacement with a five year 100% parts and labor warranty and in-home service. Imperial (made in USA) is the only range hood manufacturer that offers this. More information here:
Jul 12, 2010 | Frigidaire (PL36WC40EC) Stainless Steel...
I have a Whirlpool range hood model #RH4930XD81 approx. 10 years old. A few months ago, the light and vent fan just quit working. They were both working fine and just would not turn on one day. Any...
probably need new replacement parts......... new hoods these days start out at like 60 dollars,,, i would probably replace the unit with the age of it, because the parts needed for that will exceed prob 150 dollars
Feb 05, 2010 | Range Hoods
Hi my Kuppersbusch fan is not working. Is this common, any suggestion?
My extractor hoods lights have stopped working(2X 20W). I've replaced the bulbs with new ones but no joy!
Any suggestions?
Carl Dally
Oct 23, 2009 | Kuppersbusch K IKD12250.0E Island Range...
Range master 50000 exhaust fan stopped working
Extremely likely the fan motor.  get to it then , after removing fan blade,plug it in directly to a 110v  outlet ,just for a second to see if it works well( don;t touch it while prefoming this test,only the plug), or jumper out the switch(with electric disconnected) momentairly to see if the fan runs after turning the electric back on.
Jan 07, 2009 | Rangemaster Kitchen Hood
Wobbly Fan----Nutone Whispaire WA6500
Definetly need a new blade
#K7458-000 Boan/nutone part number
Dec 09, 2008 | Broan-NuTone Intermediate Whispaire ...
Neff extractor fan not working
Hi rags116,
I'm Harvey the Master Plumber.
Your problem is: You have a neff extractor fan which hasstopped working. The light and fan have both stopped working. Do I know where you can find the fuse as you suspect that this may be the problem. If I don't think it is the fuse would I be able to suggest anything else.
The type is D-AY25-8 If there is another number that is more helpful please let you know. thanks Again your Neff Series 2 extractor has stopped working and you want to save yourself buying a new one!! Any suggestions greatly appreciated!
Since both light and fan require low voltage it sounds like a bad transformer. It will be mounted next to the motor. Make sure you turn off the power first.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Sep 24, 2008 | Range Hoods
Light doesn't work on Kenmore Model 55022 Range hood...
If you're getting 120V at the lampholders, yet it's not lighting lamps that still work perfectly well in other fittings, two possibilitiesspring to mind.
One is that the cap on the bulbs isn't quite compatible with the fitting. Assuming they're some variant of Edison Screw, make sure that the centre terminal in the lampholder is sticking out far enough to touch the terminal on the bulb. Also check whether the lampholder achieves it's outer connection just with a small tab, rather than with the whole of the threaded ring. If so, make sure that this is going to touch the appropriate part of the bulb.
The other possibility is that you've got a high resistance connection somewhere - not enough of an open circuit to drop the 120 V when feeding the Megohm load presented by a meter, but more than enough to kill the supply when you have a lamp load. Only way to chase this is to use the meter on ohms range to bell out all the wiring between the lampholders and bits of the system which do work properly.
Apr 05, 2008 | Range Hoods
KitchenAid KWVU265YBA
had same problem. microcomputer part # 4360092 and micro switch part # 4360362 needed to be replaced. cost 255.95 and 23.59 for parts respectively.
Feb 25, 2008 | KitchenAid KWVU265YBA Kitchen Hood
Range Hoods Logo
298 people viewed this question
Top Broan-NuTone Range Hoods Experts
Richard Roth
Richard Roth
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Range Hood Expert? Answer questions, earn points and help others
