Cars & Trucks Logo
Bonnie Puchi Posted on Jun 12, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am getting codes po300, po315 and po339 - Cars & Trucks
johnny rebel
Level 3:
Top Expert:
  • Cars & Trucks Master 10,875 Answers
  • Posted on Jun 12, 2015
 johnny rebel
Level 3:
Top Expert:
Answers
10875
Questions
0
Helped
2942071
Points
47944
Definition of Diagnostic Trouble Code P0300 Category: Powertrain Definition: Random/Multiple Cylinder Misfire Detected
Definition of Diagnostic Trouble Code P0315 Category: Powertrain Definition: Crankshaft Position System Variation Not Learned
Definition of Diagnostic Trouble Code P0339 Category: Powertrain Definition: Crankshaft Position Sensor "A" Circuit Intermittent
1helpful
2answers
2009 Chrysler Pt cruiser check engine light flashing
Dont change things if udont know solution..its just guessin. A flashin enginelite means danger. It often means the catylitic converter is bad. But hav adata stream run at a privateshop to get values to target issue. Codes are jyst approximate n general
I had the bcm replaced, the code po315 appeared and impossible to delete it and the manual mode of the transmission does not work. Should it reprogram the bcm or has no link?
you can get guide from many sites.. i know few
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassemb ly, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
What does obd2 code Po315 Crankshaft Position System Variation Not Learned mean?
you can read through the suggested answers and you can read through this discussion to get insight into the problem. Dodge Codes P0315 and P0339
PO315 Code?
You tell us why they could not clear data
You clear all data,not just one code
The code came back because that system
was not repaired yet & now the shop wants to
get away from your car & work on easier money
making jobs
If you google your PO315 --- the shops really don't
have to go to their data base, as there is info on the problem
on the internet
They either never found the real issue or put one in the car
I think they ran out of knowledge
You appear to still have CPS issues
They could not clear the code because the computer
can not recognize the crank sensor
You & I can see some of the possibles on the computer,
why can't a shop
Scan tool data would show all sorts of issues
They never road tested or looked at data-- to confirm any
work they did
Read the info on that code PO315 for a chevy
You do not give back a vehicle until you drive it 20 miles
or more & all but the Evap Monitors runs & you have no
OBD Codes in memory & confirm your work
Need a better shop for sure
2008 town and country po339
That code could be from bad plugs. There is a chance that the wires to the plug are bad and also the wires to the crank sensor could be having problems. Keep in mind that the crank sensor has another part on the crank shaft that can have problems too.
1helpful
2012 ford mustang
Code 315 involves the crank sensor, and code 715 involves the speed sensor in the transmission.
Both sensors would need to be checked, and I would think the car is still covered under the factory warranty.
2helpful
Have enjine codes on 1996 chevy blazer 4.3 that read po339/po341 what is the recommentded fix
both codes refer to Crankshaft position sensor A code 339 is CKT Intermittent and 341 is CKT Range Performance. you may have to replace the sensor.
Po300 code multi cyl misfire any sugg
The code you got may not have indicated the correct coil, that was bad
I would put the old coil back in #6 & either walk the new coil to another cylinder, or get professonal help in the form of a scan tool in Mode $06,
if applicable on your vehicle & check for misfires that why
Forget the PO300
I have a Honda Accord 2004 with a code PO339, PO113 &PO344. can you assist in advice to solve these problems
p0339 is crank shaft position sensor related error. you need to be sure that its wiring is not damaged and it is not shorted somehow. if it is broken or getting broken, car may stall, or wont start att all.
p0113 is for intake air tempoerature sensor errors. that sensor measures air ehich enters the engine. it is least important. its effect may not be noticable when weather is not extremely cold.
p0334 is for knock sensor on engine. it prevent predetonation due to ignition conditions appear. it is felt when engine is under load like climbing, and engine speed is low. check for wires if it is ok replace sensor.
we can tell that temperature sensor is not directly effects other sensors.
but knock sensor and crank position sensor is to important for engine. if you have no starting issues, even cold or warm engine, invest on knock sensor first.
8helpful
I have a codes P0073 P0339 and P0335 what a re each of them?
CODE POO73- OUT SIDE AIR TEMPERATURE SENSOR CODE PO339- CRANKSHAFT POSITION SENSOR CIRCUIT INTERMITTENT. CODE PO335 -CRANKSHAFT POSITION SENSOR CIRCUIT MALFUNCTION.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
