Question about Mitsubishi WD-52725 52". Rear Projection HDTV
My Mitsubishi WD-52725 will turn off while watching and the lamp led will go red. It will sometimes come back on without unplugging and sometimes you must unplug wait 2 minutes and the plug back in. I have replaced the lamp with a new one and it did not fix the problem.
  • Mitsubishi Master
  • 8,617 Answers
Thats a common symptom of when the power board capacitors fail. It will make the lamp light turn red and a self diagnosis 34 for lamp abnormality. Usually install the power board repair kit will solve that issue. Heres a link to the power board repair kit for your model. The kit contains the capacitors and detailed instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Posted on Jul 11, 2009
I have a mitsubishi WD-52725. the red lamp light was on and I replaced the lamp. the red lamp light came back on after replacing with a new lamp. Could there be another problem
Yes the capacvitors on the power board can cause the red lamp light and a 34 error code. The V26 Power repair kit from www.tvrepairworld.com will usually solve that issue. The kit contains the upgraded caps and the CD with instructions for the repair.
Jul 03, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi model WD-52725 has a fast blinking timer light on constantly and tv will not power up. Tried unplugging and resetting with no success. Now What?
It sounds like you need to replace the lamp for your TV unit. Also don't forget to replace the lamp use hours timer otherwise the TV unit will not recognize a new lamp has been installed. I hope this helps. Good luck.
Sep 17, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Had a power surge and now the lamp notification is on steadily
This is a common problem and usually shows up when power is interrupted. The capacitors in the micro, digital, and power supply have to be replaced. In my shop, we prefer to send the chassis to Mitsubishi and they repair it. Do you have a local authorized Mitsubishi service center near you?
May 28, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Blinking green status light
Unplug for a few minutes then plug back in to try to reset it. Sometimes it could take as long as overnight before pluging back in to reset. Number of blinks is usually a trouble code.
Mar 15, 2010 | Mitsubishi WD-52725 52". Rear Projection...
I have a Mitsubishi WD-52725 projection TV .I replaced the lamp ,but the red lamp light still flashes and the TV does not turn on
the computer in your tv is bad, but someone can fix your problem , just need replace capacitors 1000 to 16 v
Jan 19, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Green diagonal lines across picture on Mitsubishi WD-52725 TV
If the lamp light turns red and the set wont power up put the V26 Power repair kit in and that should take care of it. The kit contains the capacitors and detailed instructions on CD
Jul 22, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Replaced lamp, sound but no picture
Try unplugging the set for 5 minutes and then replug it in, allow 70 seconds for it to boot up (LED stops blinking). See if it works then. If not press the input/device button and menu button at the same time read a 2 digit code (blinking led) flashes first # short pause and the flashes 2nd #. This will be necissary to determine your cause. Most common besides lamp is power supply caps that cause intermittant operation.
Dec 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP overheating
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
Dec 07, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Another problem with my 52725
It may very well be a connection issue with one of the wire connections as its not giving you a error code. I would double check the wire plug connections
Jul 28, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
270 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
