Question about Nintendo Professor Layton & the Curious Village Games for DS
__ _ _ _ _ minus 0 _ _ _ _ =33333 - Nintendo Professor Layton & the Curious Village Games for DS
    Novelist:
  • 180 Answers
The hints tell you that the solution is 412xx - 7xxx.
Looking at the 2 in the top row, the corresponding number in the bottom row must therefore be 9, giving you 412xx - 79xx.
This leaves you with the numbers 3568 to make two two-digit numbers that have a difference of 33.
You can find the two possible solutions here if you need it
http://professorlaytonwalkthrough.blogspot.com/2008/02/puzzle099.html
Posted on Jul 13, 2009
Answer always appearing
Minus and change-sign are two completely different things. Minus is used to subtract one number from another. When you press minus when the input line is empty, your telling the calculator to subtract. The only way it can subtract the number you're about to put in is to subtract it from something else, and that something else is the previous answer, hence the "Ans."
If you want to input a negative number, use the change-sign key. If you want to subtract one number from another number, use the minus key.
Try pressing the plus key when the input line is empty. You'll get Ans+ in this case as well, The same with multiply and divide, among others, and for the same reason.
Sep 23, 2013 | Texas Instruments TI-84 Plus Calculator
What do the plus and minus numbers mean on eye prescriptions? I have a minus 2 number in one eye and minus 2.5 in the other and I have no idea what that means.
Basically the numbers are an indication of your vision level. Minus numbers refer to being nearsighted (also known as short sighted). Plus numbers are far sighted (also known as long sighted).
So if you have a minus number it means that you have trouble seeing things in the distance but can probably see things that are close to you without any problems.
Feb 13, 2013 | Health & Beauty
Minus chips on my account
I want to play zynga poker again please remove the existing minus on my chips
Nov 22, 2012 | Zynga Texas HoldEm Poker
2x minus x cube plus 5x minus 2
Your question is interpreted in following way as it is not clear as cube of what & minus of what?
2x minus x cube plus 5 x minus 2
Solution 1:
= 2 x -1 x cube plus 5 x minus 2
= -2x cube plus 5 x minus 2
= cube of -2 plus 5 x minus 2
= (-8 +5) x -2
= -3 x -2
= 6
Solution2:
=2x-1x cube of +5 x -2
= -2 x 125 x -2
= 500
I think logically the solution 2 must be right. How you interpret the question is important.
sonsunny
Jul 04, 2011 | Acer Computers & Internet
Rachellewis250@I have mislaid my Stoves 720 EF manual. How do I set the timer?
There are five buttons. from left to right they are Minute Minder, Cook Time, Ready Time, Plus, Minus.
To set the time of day press the Cook Time and Ready Time together and then use the plus and minus to set the time. Use the Minus button alone to change the alarm tone.
To set the Minute Minder, press the button and use the Plus and Minus to set the time period. To cancel use the Minus to ge back to 00.00
Jan 07, 2011 | Stoves 720EF Electric Double Oven
I cannot turn on the bottom oven on my stoves and I believe it's because the clock is incorrect and I don't know how to change it.
To set the Minute Minder, press the button and use the Plus and Minus to set the time period. To cancel use the Minus to ge back to 00.00.
Dec 23, 2010 | Stoves 720EF Electric Double Oven
Minus Key doesn't work. all other keys work fine.
Please define the "-" minus key. Are you talking about the PC's keyboard or a button on the printer's front panel.
Also, what is the make and model of the printer.
Don
Feb 27, 2010 | HP PSC 1210 All-In-One InkJet Printer
Err:syntax when I try to graph with ''-'' on ti-84 plus
The calculator has two minus signs
  1. The regular MINUS sign which is used with the subtraction operation. This operation is binary, requiring two operands (two terms). In a-b, a and be are the operands (they very specific names, but I will skip this detail).
  2. The negation or change sign. This operation is called unary, requiring one operand. -a means take the negative of the number a.
These are the technicalities, in which you may not be interested. On calculators, the two operations are implemented differently, with two signs, the regular minus sign -- , and the change sign (-) usually smaller in size than the regular -- sign and raised above the main line.
Examples. Let (-) be the negation and -- the regular minus.
  • If you enter (-) 12 the TI84Plus accepts it and calculates the negative of 12.
  • If you enter 12 (-) 13 the TI protests with a syntax error
  • If you enter 12 ( (-) 13) the calculator interprets it as 12* (-13) and calculates -156.
  • If you enter --12, the calculator displays Ans--12, where Ans is the last result calculated. If Ans happens to be 0, the new result is obviously the one you are expecting. But if Ans holds a non zero value, this is incorrect.
Suppose you have to calculate X^(-2)*X^(-1/3)
You can enter it exactly as it is written above. In this case, you must use the change sign (-) in both factors.
You can also decide to use the power rules and enter the expression as X^( -2 --1/3). In this case the first minus is the negation and the second is the regular minus.
I could go on with a few more examples, but that will take us away from your present concern.
In short.
  1. If the minus sign is the leftmost (first) symbol in your function (after the Y1=) you should use the negation. Any subsequent minus should be the regular minus --
  2. If the minus sign is the first symbol in an exponent, you must use the negation. Any subsequent minus in the expression of an exponent should be the regular minus --
I hope it did not bore you death with details you do not care to know about. I do hope that it will help you prevent this type of syntax errors.
Do not forget to rate the solution
Dec 13, 2009 | Texas Instruments TI-84 Plus Silver...
Nintendo Professor Layton & the Curious Village Games for DS Logo
148 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
