Hi there, you should ensure that the connections are all correct as a first step.Tf this is the first atteempt to use that function refer to the instructions and follow recommended procedures. If this gives no joy please add the details of what you have done as well as the model number and resubmitthe query
SOURCE: I have BUSH IDLCD26TV07HD when
This issue appears sometimes for having antenna power enabled.
The solution is to reset the eeprom.
Go to the service menu by pressing menu key on remote control, then press 9, 3, 0 and 1.
Write down all values and proceed to reset eeprom.
After reset, enter service menu again and check all the values are the same as before. If not, correct them.
Hope this helps!
SOURCE: Hi I have a bush 3d smart TV 42inch bought only a
Return to manufacturer or shop where you bought it and get a new set. The controller may need factory resetting but you don't have to put up with this and it is still under warranty.
SOURCE: Hiw do i connect my tv to the internet? 8ts a bush 40" full hd led smart tv
You really need to read the manual to your TV. You need to have a router connected to a high speed Internet service. If you mean connect to the Internet, your smart TV will,have to have a browser, like Opera to enable you to get online. The smart TV apps are selectable with your remote, but you have to get the connection first. If you don't have high speed Internet and a wireless router it ain't gonna work. I don't have the manual to your set, so I can't tell you the exact steps you use on your remote control.
When I click on the internet button 'requested page can not be accessed' come up I have tried everything in the setting but can't seem to get it fixed. I really hope this extra detail can help find an answer thank you
