Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Water is sitting at bottum of dishwasher not draining very well and not washing well
  • 10,865 Answers
You most likely have a partial blockage in the drain pump or the drain line that goes from the floor of the dishwasher to the sink drain. Disconnect those parts and look. remove whatever the block age is.
Posted on Jul 11, 2009
IF you have a garbage disposal and haven't had a dishwasher hooked up to it before, it's likely you need to pop the drain plug on the disposal.
Posted on Aug 22, 2009
Dishwasher washes but won't drain
sounds like the drain may be blocked by food or other items check that first
Apr 06, 2014 | Frigidaire 18" Built-In Dishwasher
How do I drain my dishwasher?
As far as draining the backed up water you may have to run a short cycle wash to help it. In California homes we have a by-pass vent which runs from the dishwasher drain hose up to a port in the kitchen sink. From there it is attached to the side port of a garbage disposer. In the event of a backwash the by-pass vent is high enough that it can't reach a level that wiould flow back into the dishwasher.
Jan 04, 2013 | Dishwashers
I have got DWN 38 L Bendix dishwasher, problem is that during the wash cycle water starts to come under the washer. To ,me it looks like it can't take the water out.
If water is collecting under the dishwasher then there could be a few reasons.
1. door gasket is leaking - check for defect and replace if required
2. the wash or drain pump could be leaking water. Seals are not sitting properly or drain hose is cracked.
Feb 15, 2011 | Tricity Bendix 24 in. DH104 Free-Standing...
Water will not drain. water is trying to drain out & comes out in front. Disposal & sink drain is clear.
There is a outlet hose. Disconnect it into a pale. See if anything comes out.
There are areas in the washer that can pick up debris and plugg.the hose at the bottum of the washer
Check the inside lower portion of the washer for debri
Mar 24, 2010 | Dishwashers
Dishwasher isnt pumping the water out
Check the drain pipeline of your dishwasher if it is working or clogged. There's a good possibility that it is clogged. So, check these areas well. Send in your
e-mail so we can assist you further.
Oct 14, 2009 | Tricity Bendix 18 in. DH090 Free-standing...
Water not draining out after wash
take your drain hose loose under the sink and see if it will drain in a bucket or something
Apr 29, 2009 | Dishwashers
Dishwasher will not drain water. Put Drain-O in did not work,ran short cycle water on floor. HELP
My Whirlpool Diswasher did not drain water. The same water has been recycling from washing thru rinsing and sitting there after done.
Model: S62NXPLP-7624
Oct 03, 2008 | Dishwashers
STARTED DISHWASHER BEFORE BED--WENT TO EMPTY IN THE MORNING AND FOUND SOAP ON THE DISHES AND WATER IN THE BOTTUM--I TRIED TO USE THE CANCEL AND DRAIN BUTTON TO DRAIN THE WATER BUT THIS FAILED --ALSO I...
Have you checked the drain filter inside the wash compartment ? If that gets clogged up with food by products, the water cannot get to the pump to be removed to your house drain. Since you did not provide a brand and model, I cannot tell you exactly where that filter is but is normally located near the lowest point of your wash cabinet. Hope that helps..
Oct 01, 2008 | Whirlpool Dishwashers
New world wd60
i made sure drain hose was not blocked found gunk at bottum , but to reset alarm e4 , had to drain dishwasher put it on its side - must have remove an airlock. checked turn on and e4 had gone , all ok now suggest rinse all dishes before washing
Aug 24, 2008 | Stoves 27 in. DW60 Built-in Dishwasher
Problem with my dishwasher not draining at all.....
Has this Dishwasher ever drained at all? In installations the need to have a drain line attached to a disposal system is top on the list, how ever some times the connection is made but a small plug in the disposal on the inside of the wall of the grinding chamber has to be knocked out to allow for proper draining of the dishwasher water.
Aug 20, 2007 | GE PDW8200NWW / PDW8200NBB Dishwasher
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
401 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Archie Ferrarini
Archie Ferrarini
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
