Question about Sony Ericsson w580i Cellular Phone
My sony w580's display is unable to see.
I had done nothing wrong as per my observation.it was working at night but when i saw it to morning i was unable to find menu's of it and its screen was fully bluish. i shown this to shop they told that its dispay is clear it has interior problem.the handset has completed just 6 month after which it had problem. please also tell me sony care at nashik.
  • 3 Answers
Ok. The most probable problem is that the display is loose. heres what u should do. First, slide the phone open and open the top cover of the phone by first removing the top right corner first. Now, carefully remove the display by lifting the bottom of the display first and pulling it out. now, using sticky tape, stick the end of the circuit comin out of the display to the socket in the phone. Be sure to match it properly. now, carefully insert the display back by sliding the top part in and then clickin the bottom into place. Replace the cover and turn the phone on;. If this doesnt work then u hav to dhange ur display.NOTE: this will void ur warranty... do so at ur own risk
Posted on Mar 30, 2010
Xpera arc totally dead after charging
mostly it seems like a software problem. Did you try restarting it by pressing VOLUME DOWN + POWER button??
if it's not working , then take it to a service center and re-flash the software once.
Nov 06, 2013 | Sony Ericsson Xperia LT15i Arc X12...
Unlock sony ericsson w580 unlock
Hi, You can unlock a Sony Ericsson W580 safer and easier using unlock code. You can get the accurate unlock code for your Sony Ericsson W580 from www.simpleunlocking.com/sony-ericsson-w580/rs16wp9/ at low cost. You can then visit www.mobileunlockguide.com/sony-ericsson-w580 This site provides free step by step unlocking instructions. This could help you understand unlocking process better,
Nov 29, 2012 | Nokia Cell Phones
Getting a blank white screen on Sony Ericsson F305...It was working fine two days ago and just last night and this morning I'm getting a blank white screen. I'm unable to access anything and even turning...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck
Jun 29, 2010 | Sony Ericsson F305 White +512MB Unlocked...
Ive got a sony ericsson w580 which was working fine untill this morning when i went to send a text message it wouldnt let me, it sent the message to the outbox
hey katrina.....please consult your service provider and do check if someone has changed your message center number.....if there is a problem anywhere it is with your network provider and surely not with your cell......hope this helps...
Sep 09, 2009 | Sony Ericsson w580i Cellular Phone
Lcd light
More than likely you will need to replace the LCD screen. The backlight may have burned out making it blank.
A new LCD screen runs about 15 dollars shipped from ebay2.gif.
The W580i LCD screen is very easy to replace. Probably one of the easiest I have ever done.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony W580i LCD Screen Replacement
I hope that helps you out
Jul 24, 2009 | Sony Ericsson Walkman W810i Cellular Phone
How much does it cost to flash sony ericsson s500 to cricket
simple answer, nothing if you can find the firmware for the phone, in fact s500 can be flashed to w580!
if you follow this procedure carefully http://forums.se-nse.net/index.php?showtopic=36780
firmware you will need is here http://www.iprotebe.cz/firmware-section2.html (free but need to register)
if you decide you want to make it a w580 just use w580 firmware instead of s500 :)
Jul 10, 2009 | Sony Ericsson S500i Cellular Phone
Sony ericsson W580 cell phone
More than likely you will need to replace the LCD screen. The backlight may have burned out making it blank or it the LCD connector may have come loose.
A new LCD screen runs about 15 dollars shipped from ebay.
The W580i LCD is easy, easy to replace. Probably one of the easiest I have ever done.
Jun 10, 2009 | Sony Ericsson Walkman W810i Cellular Phone
I need the directions on how to change out the faceplate on my sony ecrisson 580
Follow this guide. It is for the W580 LCd screen but covers taking off the faceplate.
Sony Ericsson W580 Display Removal
Feb 20, 2009 | Sony Ericsson w580i Cellular Phone
05 EXPEDITION ELECTRONIC PROBLEM
needs reprogramming covered under a tsb at the dealer
Feb 09, 2009 | 2000 Ford Expedition
Sony Ericsson w580i Cellular Phone Logo
98 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
