Hi, I have HP Pavilion dv6633us Notebook PC, I want to reinstall vista on my laptop as i'm unable to use some of the features properly such as IIS. Its giving some error while runing .Net application. Please helpin reinstalling Vista or installing XP. Thanks in advance!!
Describe how to reslove my HCL laptop touch pad mouse is not working
Hi here is the link to download your driver to reinstall pads mouse click my name to download and select your operating system Vista ,Vista c64 or Win7
Good luck Techbelkin
Nov 02, 2010 | HP Pavilion dv5-1000us Notebook PC
HOW DO I REINSTALL THE INBUILT HP WEBCAM WITH MY COMPUTER
download its driver from the HP site, then run the setup
Nov 03, 2008 | HP Pavilion dv6000z Notebook
My laptop doesn't hubernate
Not sure whether you are using XP or Vista in your notebook.
However, if you are using Vista, you need to manually enable the Hibernation option since this option will be disabled by default. You can find the instructions to enable or disable Hibernation option in Vista from Microsoft through the link provided below :
http://support.microsoft.com/?kbid=920730
However, if you are using XP, I recommend you to reinstall the Power management features which should fix the issue by following the instructions provided below :
Please follow the steps to go to Device Manager :
1.  Click Start, select Control Panel, and then choose Performance and Maintenance. 2.  Click the System icon to open the System properties window. 3.  Select the Hardware tab and click Device Manager. 4.  Click the plus (+) sign next to System Devices. 5.  Right-click the ACPI Fixed Features button and select Uninstall. 6.  Restart the system.
Restarting the Computer will automatically reinstall the Power Management features.
Additionally, you an also download and install the latest Chipset Drivers in the Notebook as an alternative.
Hope this works.
Sep 23, 2008 | HP Pavilion dv6000z Notebook
Webcam driver
unfortantly because you have downgraded from the most advaned microsoft program there is, you dont have all the fetures that vista has.
in order to get the features back, you need to reinstall vista again.
Jul 28, 2008 | HP Pavilion dv6000z Notebook
Sound is not working on my hp laptop
did you RESTORE the OS or did you reformat and REINSTALL the OS? if you did a complete reformat and reinstall either 1) the software has changed Firmware settings and messed up the hardware or 2) The Reinstalling process has installed similarly unfunctional drivers or 3) there is an unrelated problem that is the real cause of the issue.
I'd try getting ahold of a whole set of drivers and trying each one. You might also want to look into BIOS updates for the HP, they might have fixed the issue already.
Apr 29, 2008 | HP Pavilion dv6000z Notebook
Tally 7.2
hai
the tally may not install with Vista basic.
you can install with windows xp and copy the folder named as Tally 7.2 to your vista machine then you can use the tally directly from that folder
Mar 19, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
107 people viewed this question
Alun Cox
David Payne
David Payne
