These heaters are not designed to be operated below 40 degrees F. If the heater is used below 40 and if you have a gas tank containing less than 25%, the unit will not operate for long and will start going out. If the heater all of a sudden goes out without showing any flickering or pulsations, you have a bad gas valve, there is no thermocouple on this model. Fill your tank and try the heater again. If it continues, give Coleman a call at 800-835-3278.
I have a Charmglow heater, Model HBL-155DLP/M20...both heater lights don't come on...fan works and...
(More)
I have a Charmglow heater, Model HBL-155DLP/M20...both heater lights don't come on...fan works and flame works, but no heat. Unit only worked for a few times, then this happened. How can I troubleshoot to see what part needs to be replaced. Thanks.
I have a Coleman Cal Cooperage 107 hot tub. We recently had a power surge. Hot tub turns on but...
(More)
I have a Coleman Cal Cooperage 107 hot tub. We recently had a power surge. Hot tub turns on but neither pump works. Both fuses are good. Electrician just checked them. No reset on pumps. Any ideas?
haven't used for a long time Colemann 5040; light works, heater does not / Any suggestions ; valve...
(More)
haven't used for a long time Colemann 5040; light works, heater does not / Any suggestions ; valve problem ?
I have disassembled a large portion of the unit. I can hear the propoane coming out at the top with...
(More)
I have disassembled a large portion of the unit. I can hear the propoane coming out at the top with a slight hissing noice but the smell of propane is very slight. The propane tank is full and functional and I have cleaned out the top section where the gas is emitted. Has the regulator gone bad or is there another issue?
