When I power on the device work fine with a fine clear sound. After around 10 to 15 minutes the sound is disturbed by a very annoying noise that go louder. After searching over internet some peoples said that I must replace a little transmormer and I did it with one delivering the same power. But I still have the same problem. I know this model is old and there are better units but I don't want to throw it cause I realy like the sound it delivers. Can anyone help me please? Thanks in advance.
SOURCE: On my SONY DAV-HDX279W, the module that runs the
are you using the speakers that come with it? its not typically recomended to use speakers not included with your htib system due to the diffrence in nominal ohms. however if you are using the original speakers check to see that the positive and negative wires are not touching. also check to see that there are no loose or cut wires if you have taken all of these precautions then most likely your unit is over heating due to prolonged use
