Question about Sony KDF-50E2000 50" HDTV
Red haze over top couple of inches of screen - Sony KDF-50E2000 50" HDTV
  • dcs11173 May 11, 2010
    Are you seeing speckles yet. Sounds like the onset of a bad LCD. Do a google search about sony faulty lcd.
  • Nasmi Memet Jan 16, 2012
    Is there any thing that I can do without going to SONY warranty service? As its warranty period is now over.
  • 556 Answers
YOU HAVE A BAD LIGHT ENGINE BUT YOU ARE IN LUCK CALL SONY THE WARRANTY HAS BEEN EXTENDED ON THE KDF50E2000 UNTIL JUNE 30, 2010.
Posted on Sep 14, 2009
I have had this camera for a couple of years. Just recently the pictures are blurry with red haze. I have reset settings but still no good. Any ideas?
The sensor could be damaged, that is the red haze. You probably dropped it a couple of times and the inner optics are missaligned and/or damaged. The only thing you could do is get professional help from a local electronist, or contact your local Casio dealer for help.
Apr 07, 2010 | Casio EXILIM ZOOM EX-Z60 Digital Camera
I had been getting the bulb life low message so after it went completly went out i replaced the bulb. my tv was absolutely fine before now it has a red haze on the top of the screen and it was not staying...
Power supply for a red haze problem? Doesn't sound like a powersupply issue. If its a red haze that Im thinking aobut, you might as well buy a new set. It'll be a little too costly to fix.
When it was shutting down, what was the red light blinking before it paused then repeated?
Dec 29, 2009 | Sony KDF-50E2000 50" HDTV
Whem first turned on has a white haze once it is warmed up it has a red haze in the dark scenes i have a 42 inch lg plasma
Contact your LG dealer to arrange a service call & have the software version updated, an older software may be present in the TV which can give a white screen start up problem
Nov 22, 2009 | LG 42PC3D 42 in. Plasma Television
Red haze on right side of the screen
It is usally the component board in the back. It is giving out 5 volts less than it should.
I had the same problem with my Samsung and I called them and the guy came out and opened the back on the tv and just simply swapped some a circuit board over .
The haze will also spread as it did on mine the longer you wait .
Aug 10, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Blue Haze comes out the left side of screen top to bottom about 3 or 4 inches.
What needs to happen is three specific voltages need to be adjusted on the power supply, You need to set the Ve voltage to 100v, the Vset voltage to 188V and the Vs voltage to 190v. Monitor the set for 24 hours, if haze doesn't come back the unit is considered repaired. If haze returns, then the problem is with the panel itself and wouldn't be worth it to replace because it will cost more than the tv cost you originally
May 21, 2008 | Philips 42PF9630A 42 in. Plasma Television
Green dot in middile of my screen
The green dot in the center sounds like a burn mark on one or more of the picture tubes inside the set, and the curved lines are telling me that you have a problem in the convergence circuits. The blue haze around everything white tells me you either have a lot of dust build up on the lens over the CRTs, or your picture tube(s) are very weak. If this set is over about 12 years old, I would replace it. I doubt if you will be able to get the green dot out of the picture without changing the tubes which would be VERY expensive.
Jan 05, 2007 | Philips 60PP9401 60" Rear Projection...
Sony KDF-50E2000 50" HDTV Logo
230 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
