Question about Graco Baby Gear
Is the front tire a swivel tire? I can't get the front tire to turn at all.
  • 127 Answers
It is made to go only straight it does't swiwel.
Posted on Jul 14, 2009
When in 'swivel' mode front wheel turns wildly making it difficult to control and even stops the buggy when the wheel 'stick' at right angles to the buggy
In normal use, the front wheel needs to swivel freely - then this stroller's drive is easy and manageable with one hand (we know from extensive use with 2 kids and shopping on board).
The front wheel normally can not collide with the car. If the wheel assembly / lock is not correctly inserted, it can lock / unlock uncontrolled: try to disengage and mount the front wheel unit again.
Unsufficient tire pressure can also detoriate the drive.
Dec 20, 2015 | Regal Lager Phil & Teds Sport Buggy Double...
I asked for front hub replacement diagram 1996 Oldsmobile aurora
Diagram? Pull the tire off and look at it. There's your diagram. Remove the tire, remove the CV axle nut, Loosen it/push it back some. remove the brake caliper bracket from the spindle and set it aside. Use a socket and swivel to remove the hub bolts. Pound out the hub and replace. I usually do these in 30 minutes.
Jul 17, 2015 | Oldsmobile Cars & Trucks
My snapper mower LT12D41 rod to connect two front tires came off
it's called the Tie Rod, and there are usually bolts at each end that holds a swivel to the sterring knuckle.
Jul 15, 2014 | Garden
Front wheel wont swivel
check for missing bearings in the swivel section
loose or worn shaft
replace the front wheel swivel unit
May 07, 2017 | Phil & Teds E3 Twin Seat Jogger
A loud cluncking when I turn the steering wheel to
Its the drive shaft outer swivel joint.
It needs replacing.
Oct 25, 2009 | 2000 Pontiac Sunfire
I got a 89 2500 but the fron diff isnt working the drive shaft is turing going into the diff but the tires anrt turning i was told it some pin inside the diff
If the shaft is spinning thn theres nothing worng with the diff...(if i read right what you explained), the problem seems to be the drive shaft,probabely the splines at the front hud is gone or maybe the swivel joint has given up.
Oct 25, 2009 | 1989 Chevrolet K1500
Heat Coil Needs to be replace
If you have a leak on the inside of the front tyre this is the swivel hub leaking. Go to ebay and look up "swivel hub grease". You need to replace the swivel hub oil with one shot grease.
MickyDrew
Feb 28, 2009 | 2000 Land Rover Range Rover
1988 Land cruiser front end vibration from wheels
change the swivel bearing each side you got 2bearing do prober adjustment.
good luck
Dec 31, 2008 | 1988 Toyota Land Cruiser
Baby trend expedition double jogging stroller
No but if you just sort of push on one side of the handle bar it will pull it to turn without lifting the front.
Aug 25, 2008 | Baby Trend Expedition Double Jogger
Reversing
The front tires will always swivel if you try to back up. What I found that works is to just tilt back the stroller, thus lifting the front tires and then back up.
Apr 12, 2008 | Quinny Freestyle 4 Marina Stroller
Baby Gear Logo
Top Graco Baby Gear Experts
Inky Fingers
Inky Fingers
Steve Allison
Steve Allison
Colin Stickland
Colin Stickland
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
