Question about Mtd 22" Yard Machine Push Mower
Flywheel moves then stops
My 123 cc Yard Machine push mower was working fine last week, now today won't start. I took off the pull assembly and flywheel nut, if mine has a key it's different than the pics I've seen on the internet. The flywheel will turn freely when the gas handle is pulled (which also released the brake) but then it hits a "wall". The brake had an edge that's still touching the flywheel and not sure than it would make a difference.
Any ideas about a next step? Thanks in advance
  • 22 Answers
If the engine only turns half a turn or so and feels like it hits something solid my guess is a broken conrod inside the motor(check your oil level??) dismantle engine to inspect damage
Posted on Jul 20, 2009
How to replace the cranking pull cord?
Ok, the spring will more than likely unravel when you remove the pull cord cover/assembly. There is notch in the spool for winding the rope around it. So make sure the spring is wound enough to fit it in the housing. Then take the rope, already knotted and in the spool. Turn the spool in the direction that tightens the spring.Push down on spool and allow spring to retract the rope. (Don't forget to tie the knot in the rope handle before placing on mower). Then lightly clamp in vise or visegrip, or channel lock pliers. I like to use visegrips on one side, and channel locks on the other. Place over the square flywheel nut,release channelock pliers, hold with fingers tightly so the spring does not unravel. Then release visegrips and hold with other free hand, Place over flywheel nut and slide down. Re-attach with screw previously removed. Your done. Don't forget to tie the knot in the rope handle before placing on mower.
Mar 28, 2014 | Mtd 22" Yard Machine Push Mower
Broken Flywheel?
if you have aspare flywheel take the old one off take hood off and then take the nut out off the center of the old flywheel and push the break in so the flywheel dosent magitize to the coil once you do that take olld flywheel off but make shure you dont forget that little key goes in the grove when you put the new flywheel on also make shure that key is as close to the top as you can get it the tighten down ne flywheel put your hood back on and it will start just fine
May 02, 2013 | Mtd 22" Yard Machine Push Mower
When i pull the rope it backlashes half way through the pull
Hi, You have most likely sheared the flywheel key which puts the timing out. Remove the flywheel and replace the key. Regards Phil.
Jun 16, 2012 | Mtd 22" Yard Machine Push Mower
I was mowing my yard, and the grass was pretty tall. (4-5 inches, maybe 6 in some spots). I hit a tall spot and the mower started to struggle (usually recovers), but this time it didn't make it through. ...
It sounds like the flywheel key is bent and /or broken. You have to remove the flywheel to check. Remove the part containing the starter rope. Under, you will see the top of the flywheel. Remove the nut holding the cup to the flywheel.If you have a wooden mallot, lift up on one side of the flywheel and rap the shaft with the mallot. If you dont have a mallot, find a nut with the same thread as the shaft. Wind the nut on so the nutis just above the shaft. Now, holding the side of the flywheel, rap the nut with a hammer. You may have to do it several times.When the flywheel comes off, check the flywheel key. It should be in a slot on the shaft. Get a new one and replace it in the reverse order that you took it apart.Please be careful and REMOVE THE SPARK PLUG WIRE BEFORE WORKING ON THE FLYWHEEL!! Good luck...Lee
Jul 25, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Poulan 550 Series push mower won't pull start
Hmmmm,,and the plot thickens. Without seeing the unit, i would have to think that when you pull the engine control cable bar, its not releasing the brake that sits against the flywheel. These cables do stretch. Pull the engine cover and you will see the brake against the flywheel. Pull the engine control handle and watch and see if brake is releasing. If its not, replace the cable.
That would be my bet. I hope this is of some help.
May 28, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Lawn mower won't start
sound like timing is off sherd a key in flywheel
take cover off where you pull the rope and then
take off nut off flywheel its going to be tight and hard to get off but can be done take a screwdriver to hold flywheel ones the nut off look around shaft see if flywheel key is sherd
or pry off flywheel be carefull dont damage anything if sherd replace key
Jul 21, 2009 | Garden
Last thursday my mower worked perfect, 5 days later it wont start
same here!!!...found no compression/piston movement and suspect the con rod let go...only 2yrs2mths old...assembly prob that has become my prob!
Jul 05, 2009 | Mtd 22" Yard Machine Push Mower
I hit a big rock with my walk behind lawn mower and now it sounds really bad when it is running. Whats is wrong with it?
the flywheel key is broken.take the recoil cover off.take the nut off that holds the flywheel on.thake a hammer and lightly hit the flywheel oppisit side of key way.the fly wheel will come off.replace the key.replace the flywheel.replace the recoil cover and test run the mower.should be fine.let me know if this helped................
Jun 29, 2009 | Mtd 22" Yard Machine Push Mower
Pullstring pulled back...HARD..to engine
You have a partly sheared flywheel key that is making engine out of time replace flywheel key
May 06, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
237 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
lnbn1975
Morne Olivier
Are you a Mtd Garden Expert? Answer questions, earn points and help others
