Question about JVC HX-C6 Shelf System
Protect every time i turn on the stereo protect comes up and the system shuts off. so i removed the speakers completely and tried it and it still does it.should i remove the back of the stereo and check for back connections?
  • 2 more comments
  • just show Jan 26, 2008
    tower of power model, same problem
  • judytwoshoes Mar 04, 2008
    I have the same problem....I use this unit mostly for live streaming internet radio through the usb connection from my laptop. It played great yesterday, and this morning it started with the protect mode. I tried the reset...but that didn't work. I also removed all speaker wires. I did note that when the speakers were connected, there was a popping sound when turning on the unit. I have unplugged the unit and replugged it in. I always use a surge protector so I don't understand what's up with it.
  • Anonymous Jan 12, 2009
    i get so ******* tired of the same ****
  • redcat1269 Jan 18, 2009
    Hello... i have the same problem. I go to turn on my stereo and it goes into protect mode. But i do not get the popping. I have used my stereo less than a dozen times and i can not figure out why its acting up. Unfortunately, my warrantee is up as well and i think im out a stereo unless someone knows how to fix this issue.
    Genius:
  • JVC Master
  • 1,550 Answers
The audio amplifier of your device are damaged and you need to replace him.Good luck
Posted on Aug 23, 2008
My sony stereo is on protect mode what do i do
Turn volume down, remove speaker wires from back and power on, if protect stays off there is a short in the speaker wire or speaker. But if the protect comes on, the ouput ic is shorted.
Apr 27, 2012 | Audio Players & Recorders
Radio flashes (protect)cant get any stations at all
This is an indicator of an output load problem, turn unit off! remove the speaker wires from the back of the stereo, now turn power on and turn the volume down. If the word protect stays off there is a short in the wire or one of the speakers, but! if the word protect comes on " with the speakers and wires dis-connected " it indicates a short in the audio output ic pack in the stereo.
Feb 23, 2011 | Kenwood Audio Players & Recorders
My stereo won't work. Whenever I try to turn it on, it always turns off saying "protect." How can I fix this?
The protect has come on because it senses an output load problem, Turn the unit off, unhook the speakers and wires from the stereo, now turn the unit on and turn the volume down as far as it will go, this should reset the processor ic, if the word protect stays off you have a short in the wiring or bad speaker. If the protect comes back on with everything unhooked the problem is in the audio output ic pack in the stereo and will require a technician to remedy.
Jan 17, 2011 | JVC MX-KC58 Shelf System
My JVC mx-gc5 stereo says protect and then shuts off
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage (like squashed or rodent damage).
Dec 12, 2009 | JVC MX-GC5 CD Shelf System
My stereo
Disconnect your speaker boxes. If the "protect" error goes, then the speakers or wires may be at fault. If the error remains, most likely the audio output IC is blown.
Aug 31, 2008 | Sharp CD-BA200 CD Shelf System
Protect mode
i try to turn the stereo on a message saying "protect" comes up and then it shuts off
Apr 28, 2008 | JVC HX-D7 DVD Compact Stereo Audio / Video...
How to turn protect off
You cannot . This a feature that detects a short and shuts the stereo off before it can do further damage. If you can disconnect your speakers try that then turn on your stereo. If it displays protect mode your problem is internal. If it stays on try hooking up one speaker at a time to see if one of your speaker is bad. Make sure you turn off your stereo before attempting to reconnect your speakers . Good luck
Mar 03, 2008 | JVC HX-D7 Shelf System
Protect mode
Hi ,
Does your unit go into protect mode without speakers connected?.
Jango
Jan 26, 2008 | JVC HX-D7 Shelf System
Protect
Protect mode would indicate that the system is shutting down due to a fault in the output which drives the speakers. You can check the speaker wiring, are there an loose or frayed wires? Any small "whiskers" or wire touching anything? Check the wire all the way to the speaker for damage, some pets love to chew wires! Are you using the original speakers or added extra? The impedance of the speakers must be in the range shown on the back of the unit. Have you perhaps had the volume up very high? This could result in speaker damage that could also cause this error. Try disconnecting the speakers & see if the unit powers up, if it does then put the speakers back one at a time to discover the faulty one. If all this checks out OK then the output stage itself is probably faulty & that's a job for the repair shop. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 17, 2007 | JVC HXC6 500-Watt Stereo System with 5-CD...
JVC HX-C6 Shelf System Logo
157 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
