Question about Raypak Pool Heater Covers for Teledyne & 325k 400k Btu
I have a raypak 406 pool heater and i wanted to ensure i have the wiring correct
    Scholar:
  • 91 Answers
The service manual for your model heater can be found here:
http://www.raypak.com/uploads/6000.59R.pdf
Posted on Aug 22, 2009
How do I remove my Raypak 406 elec. burner tray?
turn the gas off at manual shut off valve. undo the union in gasline. remove gasline from the gasvalve. undo the hex screws that support the bottom of the burner assembly. undo the support screws around gasvalve to the firewall. slide the burner assembly out
Aug 05, 2013 | Raypak Pool & Spa
Pilot won't light
if gas check for cobwebs if ok replace pilot generator
Feb 15, 2013 | RAYPAK R406A DIGITAL MODEL 406 wCUPR0...
Can I change out a Hayward H400ID with an electric heater for the spa only? If so what electric heater product brand would you recommned. Raypak?
Hayward has manuals for each type heater, gas and electric.
http://www.hayward-pool.com/prd/In-Ground-Pool-Manuals_10201_10551_14502_-1___I.htm
Hayward also has contact page, and can probably recommend correct change-over product.
You want to switch from propane to heat-pump type.
There are likely 3 areas of difference. Read each manual and generally look for 1) unit size and capability to match spa 2) pipe connections and sizes 3) Electrical requirement
From electrical standpoint, You need GFCI-protected line from circuit breaker box, or GFCI (arc-fault) breaker. This will prevent electrocution risk around spa.
http://waterheatertimer.org/How-to-wire-GFCI.html
Wire sizes are based on volts and watt-rating of heater.
Each electrical device has rating plate showing volts and watts.
3500 watts divided by 240 volts = 14.5 amps so install double-pole 20 amp breaker and use 12 gauge wire.
1500 watts divided by 120 volts = 12.5 amps so install sinle-pole 20 amp breaker and 12 gauge wire.
http://waterheatertimer.org/Color-codewire.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 28, 2012 | Raypak Spapak Electric Spa Heater -...
New Versa 130 won't stay lit
if wired 120 volt then make sure wired correctly they come wired for 220 volt if 120 volt have to change wires if wired correctly change black and white its not rectifing
May 18, 2012 | Raypak Pool & Spa
System clicks off while in demand
make sure wiring is correct if 120 have to rewire or switch black and white wires after checking wiring
May 18, 2012 | Raypak RP2100 DIGITAL POOL HEATER R265
I am getting a ROL code on my raypak 406 gas pool heater. Does anyone know what this means?
roll out senor bad replace but check gas pressure if too low it will overheat once gas is ok then replace fusible link and clean outside of het exchange
May 11, 2012 | RAYPAK R406A DIGITAL MODEL 406 wCUPR0...
My Raypak 406A was out of propane. Now there is propane, but it wont ignite. Where can I find the manual reset button?
Sometimes when either a propane or natural gas system has air in the lines they will not work. To be safe I would recommend you call the Raypak technical support line at 800-947-2975 or800-627-2975 and they should be able to help you figure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Aug 26, 2011 | RAYPAK R406A DIGITAL MODEL 406 wCUPR0...
Raypak Pool Heater Covers for Teledyne & 325k 400k Btu Logo
328 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
