Question about Whirlpool LER4634J Electric Dryer
Which wires go where there is no diagram..there is one spot by itself then three spot in a row the colors of wire are green black white and red
    President:
  • 1,136 Answers
Hi, If you are hooking up a power cord to a dryer, the white wire goes to the middle post and the red and black go on the outer posts. The 4th wire will fasten to the ground screw just next to the access panel for the electric hook up.
If this is a 3 wire cord, put the center wire to the middle post and the outer wiers go to the outer posts. It does not matter which outer wire you put on the outer post.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 11, 2009
Diagram for installing 4 prong dryer cord on Frigidaire crown dryer
4 wire dryer cords usually have 4 colors to hook up. The dryer will have 3 screws usually in a straight row. White goes to the center screw. Red and Black can go to the 2 side screws on either side of the white. Doesn't matter which side or which color just so red is on 1 side and black on the other side. The 4th wire should be green. It is a secondary ground and can go to any screw in the dryer body. If you see a green screw near the terminal block use that for the green wire.
Mar 28, 2015 | Frigidaire Dryers
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Apr 14, 2011 | 2002 Mitsubishi Lancer
I need to switch my three prong power chord to a four prong
your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Aug 17, 2009 | Dryers
I need a wiring diagram for this stereo
FOR 16-PIN HARNESS
Pin Number Wire Color Function 1 White Left Front (+) 2 Green Left Rear (+) 3 Violet Right Rear (+) 4 Grey Right Front (+) 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front (-) 10 Green/Black Left Rear (-) 11 Violet/Black Right Rear (-) 12 Grey/Black Right Front (-) 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
FOR 9-PIN HARNESS
Pin Number Wire Color Function 1 Not Used Not Used 2 Black Ground 3 Grey Right Positive 4 Grey/Black Right Negative 5 Blue/White Amplifier Remote 6 Red 12 Volt Switched 7 Yellow 12 Volt Constant 8 White Left Positive 9 White/Black Left Negative
MAY THIS HELP YOU
Jul 04, 2009 | Sony CDX-GT210 CD Player
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Apr 05, 2009 | 1998 Honda Accord
Washing machine moter
green is ground, white is neutral, red/black is usually hot on a 1 phase 110-120v motor. (normal colors are black, white, green).
if three phase, (208-220v), green is ground, white, is neutral, black/red/blue are hot. (only uses 2 of these, so there should only be a total of 4 wires). once you have the wiring connected, turn on the motor, and check the rotation direction it turns. if it turns backwards, reverse the red/black wires, the red/white wires, or the black/white wires.
be sure you look at the data plate on the motor to determine one or three phase motor.
their should be a small diagram of which wire inside go to which other wires inside on a three phase motor and for which voltage, and are usually numbered on the individual wire.
good luck.
Nov 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a 4 leads (red, green, black, white) to connect to the three prongs in the dryer. Which wire connects to which pole? I need a diagram or visual instruction to assist me in this.
White goes in the middle and green is your ground there should be a spot on the cabinet too too attach the green ground wire.
Jul 10, 2008 | Dryers
RADIO INSTALLING
there is a code for color!? ok, wait im searching...
found it! here you go, hope it helps...
Wiring color codes are the identification colors that color the wires in your automobile. For example, if you have a British car the blue, blue and white , and blue and red wires are for the headlights. The red and white wires are for the instrument lights, and the green and white and green and red wires are for the turn lights. The color code simply identifies what that wire does. Could you imagine if all of the wires were the same color. You couldn't identify anything in a harness.
Jun 19, 2008 | 2001 Chevrolet Tahoe
Whirlpool LER4634J Electric Dryer Logo
100 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
