Question about Brother Office Equipment & Supplies
Brother MFC-9840CDW almost brand new leaking black toner. Prints text ok(sometimes a little blurry)but anything solid looks all smeared in both black and white and color. Print toner is set to paper so does not come off when you rub it but prints of graphics and pictures are unusable. Worked fine at first and then this problem started. David
  • Brother Master
  • 19,396 Answers
The problem can had been caused by a faulty toner cartridge, before asking a replacement you must ensure it is not depending on the cartridge.
First try replacing the toner cartridge with a new original one, do this after cleaning the inside of the printer.
To clean the printer inside before installing the new toner , follow instructions here:Clean your laser printer safely with these tips.
If after that the printer is still spreading toner, then the printer is defective. In that case call Brother at the number listed on the owners manual and have the printer replaced or repaired under the one year factory standard warranty.
If the fault had been caused by a non-original toner cartridge, Brother may refuse to validate the warranty.
Regards.
Posted on Jul 11, 2009
Bad copy quality, prints are good
Could be a faulty optical sensor or crud on the glass?
Jul 24, 2014 | Brother MFC-9840CDW Laser Printer
How do you turn off the drum alert after installing a new drum on the MFC-9840CDW Brother Laser printer?
Hi,I think this guys can have more helpful information about your problem.See this link:http://www.quikshiptoner.com/catalog/brother-mfc-9840cdw-toner-color-set.html#resett_drum_manualview More Info button to see how to install the Drum unit. Pay attentionthat after replacing a Drum unit in Brother MFC-9840CDW you have to reset thecounter. See steps 9, 10 and 11 for doing so.9) Close thefront cover, plug the power cable back in and turn on the printer.10) Press the Menu button,and then enter the number 84 to access the Reset Menu.11) Press the scroll keys until Drum is displayed and press OK.
I hope this can be helpful for you.
Jan 15, 2011 | Brother MFC-9840CDW Laser Printer
Brother MFC-9840CDW not printing colours properly
Always use Brother toners. This is a common issue with cheap copies and remanufactured cartridges.
Jun 08, 2017 | Brother MFC-9840CDW Laser Printer
Brother MFC 9840CDW
Sometimes just a static shock can do that, you need to replace the control panel pcb to fix it.
Dec 24, 2009 | Brother MFC-9840CDW Laser Printer
Blue line on prints with blue color only
you will have to replcae the toner because it is the toner problem.
Aug 31, 2009 | Brother MFC-9840CDW Laser Printer
Brother MFC-9840CDW puts black lines on edge of paper
Does this printer have transfer and pickup rollers? If so many times these rollers go bad and can cause that problem. If it uses powdered toner, check for toner buildup near the ends of these rollers as well.
Aug 10, 2009 | Brother MFC-9840CDW Laser Printer
Brother MFC-9840CDW Wireless printing on Vista
maybe is not configured to work with vista;s sorry.
Mar 19, 2009 | Brother MFC-9840CDW Laser Printer
Low Toner Warning
Turn the unit off. Remove the cartridge and shake it back and forth. Ten place it and turn the unit back on. Also you can reset the counter on the cartridge, go to UNI KIT and look under Brother TN 110 refill support. These people sell refills. The ink you get with he printer is minimal. Also turning the printer off and back on will help with resetting. I found that there is plenty of toner left when the warning comes on.
Feb 28, 2009 | Brother MFC-9840CDW Laser Printer
Brother MFC9600 dirty printing
We were having a lot of print quality problems, similar to what you describe. We replaced the drum and it worked fine.
Nov 19, 2008 | Brother MFC 9600 All-In-One Laser Printer
61 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
