My laptop had a bad power cord it worked fine before then when i got the new cord it would not turn on the new cord works but computer still wont turn on
2 Suggested Answers
  • 9 Answers
SOURCE: laptop no power, power cord lights up
You should try unplugging the laptop from the power and taking out the battery. Then after about 30 seconds plug the battery back in and attempt to turn the computer back on.
Posted on Feb 02, 2009
I always get plugged in not charging when i charge my laptop even when it is not fully charged
If the laptop works fine off the power cord without any problems then your power cord is ok, but if the battery is not charging then the battery is probably dead and needs to be replaced. Batteries only have a useful life, and when it's over they have to be replaced.
If the laptop does not work with the power cord then either the power cord is bad or the DC Power Jack where the power cord plugs into the laptop. If either of them is bad the battery will not charge.
Check your DC Power Jack which is where the power cord plugs into the computer. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 03, 2012 | Computers & Internet
My lenovo y510 power is sometime not working.
Check the DC Power Jack where the Power Cord Plugs into the laptop.
Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Jun 03, 2012 | Lenovo IdeaPad Y510 Notebook
Gateway computer wont turn on
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 28, 2012 | Acer Gateway NV5905h Notebook
My new battery is not working with my Sony vaio laptop
What do you mean the new batter is not working? Does the computer turn on with the Power Cord? If not, the power cord is bad and cannot charge the battery. I have seen times when new batteries are defective. The new battery does not come charged so you have to plug in the power cord and let it charge overnight.
Apr 06, 2012 | Sony Computers & Internet
Laptop wont turn on
Very often this is a situation where the battery is dead and the power cord is not working. First off, check to make sure that the power cord is plugged securely in the laptop and securely in the power outlet. Is there a light glowing anywhere on the laptop? If not, you have no power going through the power cord. Check to make sure the power outlet is live. If you plug in a lamp or other device and get power, you have a bad power cord. I always keep a spare power supply cord for my portable computers. You can get them on eBay for $10 or so. When you know that your laptop is getting power through its power cord, but there is no power light glowing on your laptop, it is time to visit a computer repair shop. If the power light is glowing, but the computer will not come on, please describe what steps you are taking and what, if anything, the computer is doing.
Feb 17, 2012 | Dell Inspiron 4150 Notebook
My A215 wont stay powered up. It shut down and
Try running the computer on the Battery power and check if the power sustains. If not, then disconnect the power cord and remove the battery and leave it for a few hours then try turning it on.
If the problem exists then the power supply unit is required to be replaced. You may contact service center to get the power supply unit replaced.
Oct 01, 2009 | Toshiba Satellite A215-S7422 Notebook
Dell xps m1210 won't power up with new battery. Check notes.
If it is working fine with a fresh battery then it is not a motherboard problem. It is either a bad ac adapter jack on the motherboard or the actual ac adapter cord is not working. Try cables2go.com as they have replacement ac adapters for almost everything under the sun. Hope this helps.
Jul 10, 2009 | Computers & Internet
Laptop Not Getting Power
There could be a number of resons for this. Some thoughts:
1) Was your laptop working fine before you bought this new adapter? Eg. did it work with the previous one.
2) Are you positive that it is compatible? You should check all the power ratings against the old adapter (voltage output, current output).
3) Make sure the connector that plugs into the back of the laptop is a perfect fit. Connectors have a + and -. The outside metal ring may fit, but the inside 'pin' may be too small and not making contact with the receving part of the laptop.
4) Make sure that the connector inside the laptop has not broken. Easy way is to get a pencil with eraser and stick it in there and wiggle it around. If it moves sustantially, you may have some connector pins that have become unsoldered. If so, you need to get this fixed.
Apr 16, 2009 | Dell Inspiron 6400 Notebook
No Power
there is a chance of battery failure
Feb 14, 2009 | Dell Inspiron 600M Notebook
Laptop no power, power cord lights up
Feb 02, 2009 | Toshiba Satellite M40-S417TD Notebook
Computers & Internet Logo
61 people viewed this question
Alun Cox
David Payne
David Payne
