Question about Motorola Mobility RAZR V3
Razor problem My v3 says unable to charge but my charger works on my blue tooth, put in a friends battery and says same thing.  Any solutions?
    Brigadier General:
  • 7,752 Answers
Re: razor problem
Have the phone service and if that does not work have the phone reflash
Posted on Dec 25, 2007
0 characters
3 Points
Motorola Razor will not charge
turn the lights off in a room while the phone is on and see if you can see a light coming from the phone while it is closed and on.if you have a new battery did you let it fully charge before using.make sure the blue tooth is turned off.
May 13, 2010 | Motorola Mobility RAZR V3
I try to charge my razor using my blackberry charger but it wont work it keeps saying "unable to charge" why?
from explanation this means that you are trying to charge your razor with another phone charger , it will not work out for them self because they are not compatible .
what you need to get your razor phone is the type of his own charger ,but if you can not fine it own charger then you will have to go the store together with your razor phone then will help in locating it own charger that will work for with out any damage on your phone
thank you and thanks for using fixya.
Apr 11, 2010 | Motorola Mobility RAZR V3
Unable To Charge Message on Razor Cell Phone stops working off charger. Battrey shows full
My v3 has done the same sometimes I couldn`t charge then taking it off charge it used to die.
Try a new battery.
Nov 09, 2009 | Motorola Mobility RAZR V3
Razr not charging -
New charger is needed - Razors are VERY particular about their type of charge - If it is a bad charger - You will see the battery indicator flashing red - and it will be empty - this is the phone saying pretty much that it cannot use this charger -
I have had ALOT of problems with razors and returned chargers - Try to scoop up an original - or take it to a location and test the charger first -
You can try to remove the battery and then put it back in - then try to charger it but i doubt that will work -
Get a new charger - TEST IT FIRST IN STORE!!!
Good Luck!
Jul 17, 2009 | Motorola Mobility RAZR V3
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone.
Razr V3 external battery charger
May 27, 2009 | LG VX9400 Cellular Phone
Unable to charge
Um, you might need to either buy a new charger, or its your phone.
May 26, 2009 | Motorola Mobility RAZR V3
My razor v3m battery
display brigthness is a factor along with blue tooth try fully charging the battery for a long time
Jun 21, 2008 | Motorola Mobility RAZR V3
Motorola razor v3
ya try 2 change ur charger. or it got problem inside with ur charger circut. try getting external battery charger frm market. so thatur one battery can be carged and another u can use it
Jun 04, 2008 | Motorola Mobility RAZR V3
Motorola razor
you may need to have the usb charger port replaced....if that does not work try reflash the original firmware on the phone....for this to be done it is best that you take the phone to a mobile center close to you.
Dec 20, 2007 | Motorola Mobility RAZR V3
Your battery may have a low voltage, you need to rejuvenat is unfortunatly you cant do that if you dont have tools to do it, but that will be your problem (Battery)
Jan 10, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
49 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
