The cubase staimberg is not compatible with windows vista? i resently change computer and i can not use the program with mi new computer
  • 19,396 Answers
Cubase 5 and Studio 5 and later versions can be installed on any machine running Vista, including Vista 64 bit.
Older versions of Cubase will not work on Vista.
See also:
Features & Requirements
Support for PCs using Microsoft Windows Vista
More information on operating system compatibility
Regards.
Posted on Jul 11, 2009
We just got a new computer with Windows 7. We
You could try installing the version 5 on your pc. There could be a compatability issue so follow the information below if it will not install.
The Windows® Vista Program Compatibility Wizard can allow older programs that were not designed for use with Windows® Vista to run on Windows® Vista.
The Program Compatibility Wizard prompts you to test the program in different modes (environments) and with various settings. For example, if the program was originally designed to run on Windows® XP, set the compatibility mode to Windows® XP and try running the program again. If successful, the program will start in that mode each time. The wizard also allows the use of different settings, such as switching the display to 256 colors and the screen resolution to 640 x 480 pixels.
To run the Program Compatibility Wizard, complete the steps below:
  1. Close all programs and windows and return to the desktop.
  2. Click the Start button on the Windows® taskbar. The Start Menu will appear.
  3. Click on Control Panel. The Control Panel window will appear.
  4. Click on Programs. Additional program options will display.
  5. In the Programs and Features section click the link Use An Older Program With This Version of Windows. The Program Compatibility Wizard will launch.
  6. Click Next to Continue.
  7. Click the “I want to choose from a list of programs” radio button and click Next. A list of programs will display.
  8. Select the program that is to run in a Compatibility Mode and click Next to continue. A list of Compatibility Modes will display.
  9. Click the radio button next to the desired Compatibility Mode and click Next. A list of display settings will display.
    NOTE: These display settings are not available options in Windows® Vista. They are only available when running a program in Program Compatibility Mode. The only reason to choose either of these settings is if you are experiencing difficulty installing or running an older application designed to run in Windows® 95, Windows® ME or Windows® 98. If all options remain unchecked, then the current Colors and Screen Resolution settings will not be altered.
    By default, Windows® Vista uses visual themes that may change the appearance or behavior of other programs, especially those games or educational programs that include intensive graphics and animation. To prevent the visual themes from affecting these programs, check Disable Visual Themes.
  10. Choose the desired display settings and click Next to continue. Administrator privilege options will display.
  11. Choose the desired administrator privilege setting and click Next to continue. A Test Your Compatibility Settings window will display.
  12. Verify that the settings are correct. And click Next to continue.
    NOTE: If the settings are not correct, click the Back button to return to the previous screen (or screens) and make the necessary changes.
  13. With the correct settings selected and showing in the "Test Your Compatibility Settings" window, click Next. The selected program will launch.
  14. Run the program to test the settings.
  15. After testing the settings, or close the program to return to the Program Compatibility Wizard.
    NOTE: After the program is closed, a window with the question "Did the program work correctly?" will appear. The "Yes. Set this program to always use these compatibility settings" will be selected.
  16. If the program functioned properly using the compatibility mode that was selected above click Next. The Program Compatibility Data window will open.
    NOTE: If the program did not function correctly, click "No, try different compatibility settings" and complete the Wizard. After completing the wizard, try the program again.
  17. Choose Yes or Now and click Next to continue. The Completing the Program Compatibility Wizard window will appear. Click Finish to close the window.
  18. Launch and use the program.
NOTE: If you have questions regarding the Program Compatibility Wizard or Windows® Vista (or both), contact Microsoft®, or go to http://www.microsoft.com for additional information.
Apr 01, 2010 | The Learning Company The Print Shop...
I am totally lost!! All I have is the lambda lexicon and cubase LE4 on my desktop.Apparently it is not set up correctly. I want to record guitar and voice I have sound on lambda through mike and guitar but...
All it needs is a USB connection. You'll need to go into Cubase device setup and make sure your lambda drivers are selected. Then create the audio channels in cubase with the inputs set as the inputs you're using for guitar and mic. There is a monitor button right next to the record enable button that needs to be enabled if you want to hear playback from your computer.
Feb 20, 2010 | Lexicon Lambda Usb Desktop Recording...
Tascam us-144 no sound with Windows Vista
Often, you just need to ensure that your computer's native driver is disabled, this is a common problem with audio interfaces and windows. Once this is done, make sure that your Tascam is set as both the input as well as the output device for all audio-based programs. If this doesn't work, get an M-Audio . . .
Hope this helps!
Feb 26, 2009 | KEF Audio KIT100 System
Unable to install scanner
Cant find such a scanner, are you sure of the model "performance", If it is not Vista compatable, ie if Epson have not released a Vista driver, then it is not going to work with Vista.
See Epson web and download driver if available, if not change scanner or operating system or purchase software
Check your Epson product CD to see if it already contains Windows Vista drivers. If the CD indicates support for Windows Vista, follow the instructions that came with your Epson product to install your driver and other software.
If your Epson CD does not indicate support for Windows Vista, DO NOT INSERT YOUR EPSON PRODUCT SOFTWARE CD IN YOUR WINDOWS VISTA COMPUTER because the setup program is not compatible with Windows Vista. Instructions for installing additional software from your CD may be available with your driver download.
Note: If you already have ArcSoft PhotoImpression™ 5 installed on your Windows Vista computer, you may need to install a "patch" program. Go to the ArcSoft website to download and install the patch.
Products that are not Vista compatable are not capatable with Vista, who would figure hey!!
Jan 23, 2009 | Office Equipment & Supplies
I am trying to move my Bookkeeper program to a new Vista Computer. I am getting a message that I am trying to run an older version of Bookkeeper with newer pogram. My old computer is XP and the new one...
Most programs written for Windows XP also work in this version of Windows, but some older programs might run poorly or not at all. If an older program doesn't run correctly, use the Program Compatibility Wizard to simulate the behavior of earlier versions of Windows.
• Open the Program Compatibility Wizard by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
NoteTo find out if your programs (or programs you plan to buy) are compatible with Windows Vista, go online to the Windows Vista Compatibility Center. This website contains a comprehensive list of programs, computers, and devices that have been tested to work with Windows Vista.
Oct 24, 2008 | Computers & Internet
I am trying to install my software on my new computer, ia the Windows Vista
Read the system requirements of the software...if it is software made for another operating system ..... Most programs written for Windows XP also work in this version of Windows, but some older programs might run poorly or not at all. If an older program doesn't run correctly, use the Program Compatibility Wizard to simulate the behavior of earlier versions of Windows.
Oct 23, 2008 | Computers & Internet
I am trying to install Resume Workshop on my new computer and it has Vista operating system
Most programs written for Windows XP also work in this version of Windows, but some older programs might run poorly or not at all. If a program written for an earlier version of Windows doesn't run correctly, use the Program Compatibility Wizard to change the compatibility settings for the program. To change settings for a program manually, use the individual program's Compatibility tab.
If changing the settings does not fix the problem, go to the program manufacturer's website to see if there is an update for the program.
How to Run the Program Compatibility Wizard 1. Open the Program Compatibility Wizard by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
2. Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
Jul 03, 2008 | Computers & Internet
Cant record
i was having a simillar problem, but i was using xp. try going into cubase and under devices try puting it as "mackie control" you computer should recognize it as lambada usb. i hope that helps =)
Jul 03, 2008 | Lexicon Lambda Usb Desktop Recording...
Firebox and cubase se not workin
https://www.steinberg.net/1069+M52087573ab0.html, If u have purchased the software,just go to this this link,register ur product. U will get the steinberg cubase customer care, just try contacting them and rectifying the problem, because this is too specific and technical.BEST OF LUCK!!!! THANK U!!!!
Jun 21, 2008 | Steinberg Cubase SE
Hi which version of Cubase you are using / have you download it from somewhere or Just bought it ?
Jan 19, 2008 | Steinberg Cubase SE
22 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
