Cars & Trucks Logo
M
Mark Venzke Posted on Jun 11, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Diagram "fuel system" 1984 Chevrolet G-30
I need a diagram of the fuel system of a 1984 Chevrolet G-30with a 350 cu in (5.7 L0 engine and a Rochester 4 bbl QuadraJet carbuerator, so I could identify the part number of the segment of the gas line that attaches to the carbuerator.
David Harrelson
Level 3:
  • Chevrolet Master 5,456 Answers
  • Posted on Jun 12, 2015
David Harrelson
Chevrolet Master
Level 3:
Answers
5456
Questions
17
Helped
1101996
Points
15442
I usually just buy steel fuel line of the correct size and use the old line as a guide to bend up the new one. Cut off excess and make new double flare. Much cheaper than trying to buy stock part.
1helpful
What is the power of the engine of the Chevrolet K-30 Truck year 1976 ?
YOU OPEN THAT HOOD AND ASK THE BLIND?
NO ENGINE TOLD AT ALL, AND IS A PURE ENGINE QUESTION.
I GUESS YOU MEANT HORSE POWER?> OR TORQUE AT THE FLYWHEEL>?
OLD TRUCK MAY HAVE HAD 3 ENGINE SWAP NOW.
THE VIN CODE SHOWS DAY 1 ENGINE CODE THERE
BUT PERSONALLY ID GET THE ENGINE SERIAL NUMBER FIRST OFF THE ENGINE AND GOOGLE IT.
BINGO WHAT ENGINES IS THERE.
K30 PICKUP? HAD 4 ENGINES DAY1 NEW USA CHOICES
GEN3 K30
ALL GEN3 HAD SOME OF THESE OR WAS SWAPPED OUT.
BACK THEN I'D DE-TUNED MANY ENGINES TO GET 16MPG NOT 8 OR WORSE.
WITH CARB CHANGES, DID MANY
Powertrain
Engine 250 cu in (4.1 L) I6
292 cu in (4.8 L) I6
262 cu in (4.3 L) V6
305 cu in (5.0 L) V8
350 cu in (5.7 L) V8 GUESS 2
366 cu in (6.0 L) V8
400 cu in (6.6 L) V8 GUESS 1
454 cu in (7.4 L) V8
350 cu in (5.7 L) Oldsmobile Diesel V8
379 cu in (6.2 L) Detroit Diesel V8
YOU NEED HEAD AND BLOCK CASTING NUMBER TO KNOW WHAT IS REALLY THERE IF THE 8TH VIN CODE IS WRONG UNDER HOOD
400>? SAYS USED EXTENSIVELY ON TRUCK THEN,.
Early models produced 265 hp (198 kW) with a two-barrel carburetor. All 400s came with a two-barrel carburetor until 1973. A four-barrel carburetor option became available in 1974.
The 400 was never intended as a high-performance engine and never saw large factory horsepower numbers; nevertheless, it developed a reputation for creating tremendous torque (up to 400 lb?ft (542 N?m) in 1970)
OLD CARS OR TRUCKS MAY HAVE HAVE MODS
STEEL HEADERS
BETTER CARBS (FOR MORE HP OR FOR MORE MPG)
HEAD SWAPS.
1975 Chevy 350 4 barrel carburetor Vacuum diagram please?
Question edited for clarity and spelling.
Quadrajet is the carburetor made by Rochester. Vacuum information is in the link. More on the mages tab.
https://www.google.com/search?q=rochester+quadrajet+carburetor+vacuum+diagram
Diagrama sistema de encendido para camioneta Chevrolet S 10 1984
1: DOES THE STARTER CRANK FAST?
LIKE THIS. Y/N
https://freesound.org/people/drdeath666/sounds/687447/
YES IS THAT IS CALLED CRANKS GOOD BUT WILL NOT START
AND THAT HAS 50+ CAUSES.
no engine told , is car in USA or Mexico or Chile? where.
cars outside USA are very different. for sure engines. and EFI.
Gasoline:
1.95 L LR1 I4
2.0 L LQ2 I4
2.5 L L38/LN8 I4
2.8 L LR2/LL2 V6
4.3 L L35/LB4 V6
Diesel:
2.2 L LQ7 I4
which is it? we can not guess cars ,engines or countries.
so sorry ,can not.!
1984 IS 39 YEAR OLD CAR (very few run now,)
buy it dead?
BACK THEN, THERE WERE ONLY PAPER BOOKS
NO PDF, NO DIGITAL DOCUMENTS AT ALL.
THE MEANS ONLY GOOGLING FOR SCANS OF SCHEMATICS IS ONE WAY TO FIND THEm. (and to search add the engine name)
WHAT TO DO IS.
IF IT DOES CRANK IS:
  • check compression on the engine,
  • check for spark next on all cylinders, not just1.
  • now try test fuel (spray can, ) for 3 second run if cars fuel system is dead.
  • fix bad fueling if spray fuel makes engine sound good.
takes tools. , meter and gauges to find the problem.
now my wild useless guess.
bad spark plugs ,bad wires, to them
all filters clogged,
if lucky., only that. called tuneup in the olden days
1984 g 20 chevy van vaccum diagram
Check this diagrams and click over images for zoom...
Fig. 101: 1984 4.1L engine-Federal and high altitude with manual transmission (G10, 20 and 30 models)
Fig. 102: 1984 4.1L engine-Federal and high altitude with manual transmission (G10, 20 and 30 models)
Fig. 103: 1984 4.1L engine-Federal with automatic transmission (G10, 20 and 30 models)
Fig. 104: 1984 4.1L engine-Federal with automatic transmission (G10 and 30 models)
If you have any other questions or need that I send you some other diagram, please feel free to get back to CONTACT US HERE.
Also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
3answers
Spark plug wiring diagram for a 1984 corvette 350
go to a library under autosec629-chilton n mitchell books
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
