Question about Xante Ilumina Digital Color Press Printer
Red drum toning - Xante Ilumina Digital Color Press Printer
Uniden phone light WON'T flash red light when I have pulsing dial tone VM messages.
The pulsing dial tone usually indicates a message on the service provider's server, not on your phone. Contact your provider to find the procedure to access these messages.
Aug 15, 2016 | Uniden Lands Phones
How do you align the colors?
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT buttons to move a red frame pointer to
IMAGE ADJUST Menu icon.
Press POINT DOWN button to move a red frame pointer to the
item that you want to adjust. and then press SELECT button.
The level of each item is displayed. Adjust each level by
pressing POINT LEFT/RIGHT button(s).
Move a red frame pointer to
the item to be selected and
IMAGE ADJUST MENU
IMAGE LEVEL ADJUSTMENT
Press POINT LEFT button to decrease contrast, and POINT RIGHT
button to increase contrast. (From 0 to 63.)
Press POINT LEFT button to adjust image darker, and POINT
RIGHT button to adjust brighter. (From 0 to 63.)
Contrast
Brightness
Press either POINT LEFT button or POINT RIGHT button to obtain
better balance of contrast. (From 0 to 15.)
Gamma
To store manually preset image, move a red frame pointer to
Store icon and press SELECT button. Image Level Menu will
appear. Move a red frame pointer to the Image 1 to 4 where you
want to set and then press SELECT button.
Image Level Menu
Move a red frame pointer to any
of Image 1 to 4 where you want
button.
Store icon
Press SELECT button at this icon to
store the adjustment.
IMAGE ADJUST
Menu icon
Press POINT LEFT button to lighten red tone and POINT RIGHT
button to deeper tone. (From 0 to 63.)
White balance (Red)
Press POINT LEFT button to lighten green tone and POINT RIGHT
White balance (Green)
Press POINT LEFT button to lighten blue tone and POINT RIGHT
White
Jan 22, 2011 | Sanyo PLC XU35 Multimedia Projector
My dell 5100cn printer is not printing red tones at all. Everything comes out in green tones. Has new toner cartridges and drum. What can I do?
The M6090 Magenta Developer is failing. It has lost it's magnetism. So the toner isn't ready to be transferred.
The Cyan Developer G6593 or Yellow Developer H6682 may be failing too, because it can't dependably hold all it's toner. One of those is probably bad too.
Whit
Item, Inc
Aug 17, 2010 | Dell 5100cn Laser Printer
Turn on my brother hl 2170w printer -led lights up tone and drum yellow error is red and nothing else-doesnt even warm up there is no paper jam nothing-printer just sits there.
To reset the drum message:
Open the front door
Press and hold down the white button for about 4 seconds. Once all 4 LEDs are lit, release the button.
Close the front cover. Make sure that the Drum LED is now off.
Feb 09, 2010 | Brother HL-2170W Laser Printer
My Minolta CF2001 when making copies the red ink does not comes out clear on top like it does the bottom of the pictures yet there is plenty if ink in the cartridge--help me
Have you checked the half tone print out for the magenta drum. Get into tech rep mode and run half tone with just magenta see if there are any problems. Also tone up machine and run gradation adjustment. But sounds like the drum. One other thing clean the LED rack below the drum
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 10, 2009 | Minolta CF2001 Copier
Is there a way to upgrade the tone generator sounds drums, synths, etc?
No. Unfortunately you are stuck with the drum kits and standard midi that come with the 2488. I find the tone generator sounds to be pretty good on the 2488 quality-wise at least. Of course having the versatility of swapping in other kits and tones/samples would be nice. I believe Tascam discontinued the tone generator/drum machine on subsequent models of 2488 because it seems that the demand wasn't there.
Mar 23, 2009 | Tascam 2488 Portastudio Multitrack...
Red light continuous no printing
either lookat the connection between the toner/drum unit or try inserting a little more firmly? worked for me
Aug 17, 2008 | Samsung CLP 300 Laser Printer
Prints dark black instead of grey tones
your drum is going bad. or your light or dark adjustment is set too dark ( it should be in the somewhat in the middle).
change drum
Nov 06, 2007 | Sharp AR-5316 Advanced Digital Imager...
75 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ekse
Marvin
Marvin
 Mike M
Mike M
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
