Question about Gateway MX3215 Notebook
How do I replace the screen of my gateway mx3215 laptop? is there a manual to replace available?
Can Gateway MX3215 boot to usb stick?
If you go into the BIOS configuration then the Device boot order and you do not see the USB port in the list, then an USB boot up option is not available.
If it is available the move the USB as the first boot device so you can boot up with an USB memory stick.
Nov 13, 2011 | Gateway MX3215 Notebook
I HAVE A GATEWAY MX3215 LAPTOP BUT IM MISSING OR
Go to Gateways site and download the "recovery" disc info....I note that your laptop specs only has 256 MB ram which is too low to run XP. I suggest you need at least 1GB ram DDR2 whixch is the max it will handle. This will really speed it up and is relatively cheap.
Apr 13, 2010 | Gateway MX3215 Notebook
Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Mar 17, 2009 | Gateway MX3215 Notebook
Need to replace my keyboard on a Gateway mx3215.
The best way to replace the keyboard is to first order one off of ebay.
eBay links for MX3215 Keyboards
Next step is to follow the instruction manual from Gateway. Download the following PDF document, and check out page 45 in the PDF document [labled as page 41 in the manual].
Download Gateway MX3215 Hardware Manual
Best of luck!
Mar 16, 2009 | Gateway MX3215 Notebook
Gateway MX3215
that processor should work fine
Nov 13, 2008 | Gateway MT3705 Notebook
Mx3215 memory upgrading problem.
Here is a link for you open this page and enter your serial no.
Click Here
This page will tell you which one is campatable with your system.
Thanks
Iqbal
Mar 17, 2008 | Gateway MX3215 Notebook
Screen
Is this an inverter issue with the display? Is it worth fixing.
Yes, and yes.
If it is still under warranty have Gateway fix it.
If not
Go on Ebay and you may find the part cheap.
Dec 23, 2007 | Gateway MX3215 Notebook
Memory Problems for a Gateway Mx3215 Laptop
There are two different memory modules for that series.You can determine which you need by the chipset for you machine.If you have a Via VN800 Chipset You need the 1024MB-DDR333, 333MHz, PC2700, 200p SODIMM, 2.5v. If you have the NVIDIA nForce 410 Chipset The you need the 1024MB-533MHz DDR2-533 PC2-4200, 200p SODIMM, 1.8v Hope this clears up your problem
Sep 29, 2007 | Gateway MX3215 Notebook
Gateway MX3215 Notebook Logo
109 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
