Question about John Deere A,b,g Tractor Carburetor Float Dltx10
1937 JD - B CARB DLTX-10 I HAVE RECENTLY
1937 JD - B CARB DLTX-10 I HAVE RECENTLY CLEANED INSIDE PARTS BLOWN OUT PASSAGES WITH AIR, THEY SEEM TO BE OPEN TO ME, A NEW FLOAT W/NEEDLE AND SEAT THEN "ADJUSTED" FLOAT PLUS NEW GASKETS INSTALLED. I HAVE BEEN IN THE BODY SHOP BUSINESS FOR 40 YEARS AND HAVE ALL KINDS OF ENGINE EXPERIENCE,I FEEL LIKE I MUST BE MISSING SOMETHING BECAUSE THIS ONE TENDS TO BACK FIRE ON IDLE EVERY SO OFTEN AND WILL FLOOD OVER AND FILL THE CYLINDERS IF FUEL IS NOT SHUT OFF OVER NIGHT. THIS TRACTOR WAS RESTORED BY MY FATHER OVER 20 YEARS AGO AND IT'S NOW MY TRACTOR IT LOOKS AND RUNS NEAR PERFECT EXCEPT FOR THE DETAILS I HAVE DESCRIBED. I SURE WOULD LIKE TO SOLVE THIS PROBLEM , I KNOW IT'S A GOOD IDEA TO SHUT THE FUEL OFF WHEN PARKED AND I DO THAT BUT I FEEL IT MAY BE SPILLING OVER JUST ENOUGH TO CAUSE OTHER ISSUES WHILE IT'S RUNNING, DUNNNO THAT'S WHY I'M HERE.
TIM ELFRINK
TIM'S BODYWORKS
AKRON, OHIO
telfrink@neo.rr.com
  • 86 Answers
SOURCE: lawn tractor shuts off after 20 minutes of running
How old is your ? Sounds like ignition problem,If your engine is older you would have points when the points are bad they can stick together and will result in shutdown after unit cools a little it will restart !
Posted on May 09, 2009
woobie dog
  • 1273 Answers
SOURCE: 1976 JD 214 lawn mower Kohler engine K321AQS
When it shuts down crack the fuel cap and listen for the woosh of a vacuum on the fuel tank. If you hear this, clean the pinhole vent in the fuel cap, or replace it. Being partially plugged would cause you to be starved for fuel and could explain your issue, and why it goes away after a period of time.
Regards, --W/D--
Posted on Jul 19, 2009
  • 394 Answers
SOURCE: Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
Posted on Mar 13, 2010
  • 52 Answers
SOURCE: John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Posted on Apr 18, 2010
Testimonial: "Thanks for the ideas. I will try your suggestions. Tractor used for snow blowing during the winter and gas did not stay in it long. Good ideas!"
miket756
  • 2702 Answers
SOURCE: engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
Posted on May 02, 2010
On Honda 2009 Shadow Aero, Engine "bogs down" at top of throttle. I've cleaned gas tank, carb, fuel line.
Have you cleaned the carb power jets and blown them and there passages out with compressed air?.
Sep 13, 2016 | 2008 Honda ST 1300
Whilst driving my motorcycle with 5000+ rpm on the counter as I close the throttle and depress the clutch the rpm stays at 5000+ and causes problems. What is the cure?
Have you tried cleaning and lubricating the accelerator handle mechanism and the cable. Chances are there is too much goo inside that it is sticking up. The accelerator handle may have too much dirt inside or the extremities of the cable may be too much dirty.
Jun 19, 2016 | Motorcycles
04 honda 500 rubicon starts good and sounds smooth at idle but boggs down when you push throttle. new gas, cleaned carb. replaced parts carb. kit also chekd TCS any ideas need help thanks R.H.
Hi, Anonymous and the usual suspects are:
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Inlet system air leak.
4. Vacuum piston malfunction.
5. Accelerator pump leaking or no output.
6. Plugged bowl vent.
7. Fuel level in bowl too low.
8. Restricted fuel supply passages.
9. Plugged jets or passages.
10. Worn or damaged needle or needle jet.
12. The enricher valve not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.hondaforeman.com/128-foreman-450/74303-carb-driving-me-crazy.html
http://www.hondaforeman.com/149-honda-recon/69272-2005-recon-will-not-accelerate.html
Honda 450 Foreman backfiring no power but idles fine
Bogging out when give my four wheeler gas
http://www.hondampe.com.au/docs/owning_a_honda/owners_manuals/motorcycles/TRX500FA-FOURTRAX%20FOREMAN%20RUBICON-2003.pdf
http://ng-products.com/nic/honda/2007%20Honda%20Foreman%20Rubicon%20Service%20Manual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 20, 2016 | Honda Motorcycles
Craftsman rider. Only starts when I add gas to carb. Runs about 10 sec than dies. I have check all fuel lines cleaned carb. Fuel pump works. Not sure we're to go next
Sounds liek gum deposits have clogged the carb. Remove, disassemble, and soak in carb cleaner. Then blow out all passages with compressed air. Should work after that.
Jul 15, 2014 | Garden
I have a 1984 honda big red atc 200es I just got from a family member its been sittin for about 2 years so far ive totaly cleaned the carb made sure everything looked brand new inside and out it still...
Hey Anon,
Cleaning a carb is not an easy undertaking,, there are several tiny passages, tiny jets, and the needle/seat assy, If you are not trained to know these.. you may not get the carb as clean as it needs to be... Install a new spark plug... a new air filter.. and get a qualified pro to clean and set the carb.
Motorcycle ATV UTV and Snowmobile Parts and Accessories Dennis Kirk Inc
ATV repair manuals
Honda atv manuals
Jun 28, 2017 | Honda 2009 Big Red MUV
No start. If pull 300 times will seem like wants to. cleaned carb passages in and out, has spark and seems to have full compression. I give. TB32ec.
Hi Scott try cleaning the air filter and then try running with just a small amount of fuel in the block itself. If it still wont run it's most probably the gaskets on the carb.
Oct 18, 2013 | Troy-Bilt Troy-Built Gas String Trimmer...
I am trying to get a JD riding mower with a 17 HP Briggs to run that has been parked for a couple of years. Ive replaced gas & filter, cleaned carb and verified fuel pump is working. It will only run if...
You need to soak the carb in a good carb cleaner for a couple of hours then blow all passages out with compressed air, this should dislodge any junk.
Aug 20, 2013 | John Deere Garden
Craftman 6.75 turbo walk behind mower with tecumseh engine wont run fuel on sparkplug
It runs on a prime so that eliminates an ignition problem and indicates a fuel problem. You are on the right track, you just missed something in the carb. Remove the carb and clean it again. Be sure all passages are clear. you mmentioned that you replaced the inlet needle- what about the seat? They come as a set and should be replaced together. Be sure you clean the passages in the fixed jet also.
Take your time, clean the carb thouroughly and your problem should be solved.
Nov 21, 2012 | Garden
1996 XR600 Honda - idles fine and seems OK at WOT but pat throttle it's missing/coughing. Had the carb off and cleaned blew out all ports/passages no difference. Any ideas - I was heading for the plug...
got a 1996 model xr600 firing alright but not running couple of seconds and then stalls out also blown some smoke on start up for couple of sec once clears it throat seem fine
Jul 20, 2011 | Honda XR 650 R Motorcycles
My Coleman 5000 generator in storage. Gas tank was drained. New gas put in. Won't start. Gas poured down spark plug hole. l Engine will start but stops and won't start again. Is it a carburetor...
It sounds like your carb needs to be taken apart and cleaned out. The gasoline in the carb sounds like it has varnished and blocked the passages in the carb. I would try some carb cleaner, if you are comfortable in taking apart the carb, you can use the spray cleaner to open the passages. You might have to soak the carb a bit as well.
Mar 07, 2011 | Garden
John Deere A,b,g Tractor Carburetor Float Dltx10 Logo
331 people viewed this question
Top John Deere Garden Experts
Dave
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Are you a John Deere Garden Expert? Answer questions, earn points and help others
