Question about LG Refrigerators
My lg gr-l206cpqa fridge freezer keeps tripping out main fuse box in house when trying to dispense water,it started coming out slower at first but now just trips fuse. Any ideas as to cause?
  • bryan farmer Jun 12, 2015
    still think that it has to do with solenoid,that may be the problem.Will continue to investigate problem.
    New Friend:
  • 112 Answers
Switch for solenoid is bad and grounding out replace water dispenser switch.
Posted on Jun 11, 2015
Testimonial: "Thanks for reply. Would the switch be know as a microswitch ?"
  • Anonymous Jun 12, 2015
    Forgot to mention only trips out when dispensing water, both ice functions still work as they should.
SOURCE:
LG serial#GR L247NIS is making slow ice
Have you checked the temp in the freezer section? Should be near zero F - at least below 10 F. You would also be noticing ice cream being soft.
Feb 19, 2018 | Refrigerators
Hi I have an LG fridge freezer model number GR L206CPQA and there is a horrible smell coming from the water from the dispenser, the filter has been changed and the ice seems to be fine but the fans on the...
Sorry but your model number doesn't register with me in the USA.
My experience tells me that the plastic water line from the filter to the water tank to the dispenser outlet is your problem. Replace those parts and you should be ok.
Hope this helps.
Nov 14, 2011 | LG Refrigerators
Lg multi air flow gr-349sqf
It sounds like the defrost element is faulty and is causing a leakage to earth when the unit comes onto defrost cycle. Check the defrost element in the freezer compartment behind a panel cover.
Mar 10, 2009 | Refrigerators
HISSING SOUND FROM FRIDGE FREEZER
I poked a hole in the freezer with my knife while trying to defrost it. Now it is making a constant hissing sound. what should I do? is this dangerous?
Jan 23, 2009 | LG LRFC25750 Refrigerator French Door
THE MAYTAG fRIDGE/fREEZER BLOWS OFF I.E. IT SWITCES ITSELF OFF AND THE MAIN FUSE TRIPS OFF. THE PLUG FUSE NEVER BLOW OFF THOUGH.AFTER COUPLE OF DAYS,WHEN WE PLUG IN THE THE FRIDGE/FREEZER IT WORKS FINE AND...
what's the model number,i don't understand what you're asking,are you saying the fuse keeps popping in the house fuse panel?or the fridge stops running and the house fuse is ok.what is i.e.
Feb 07, 2018 | Maytag Refrigerators
Could be a wire short,bad defrost heater, or comp. pulling too many amps which is between 2 and 6 or higher being bad. I would say the main problem is you purchased a LG fridge which is a poorly made fridge,sorry.
Mar 30, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Mar 09, 2008 | Refrigerators
Refrigerators Logo
150 people viewed this question
Top LG Refrigerators Experts
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
