Dish washer will not start. Program shows that there is power, but it will not start. Door is securely shut. the other day I took the trap apart and saw about 1C of standing water below the silver grate. I did this because the dishwasher was smelling bad, thought there might be food trapped there. any ideas?
I found that by initially disconnecting the pipes and cleaning them out (without the usual...
(More)
I found that by initially disconnecting the pipes and cleaning them out (without the usual success)......then taking the front door panel off (you need to carefully remove s/steel screws from inside which then release the white or outer door panel) i found an accumulation of 'gunk' inside. Clean all of this out, make sure that rubber surround seal is 'secure' and that all inner water carriers (to tablet flap) are leak-free......re-assemble....try it!....mine is now 'as good as new' (4 back-up washes done!). good luck (POWER OFF WHEN WORKING INSIDE DOOR...WIRES!!!!!!).
