Question about Spectroniq PLTV3250 32 in. LCD TV
Get a red line around anything black on my
Get a red ring around anything black on my Spectronics 32" LCD TV....then started intermittently bleeping red over the pic like static and pic finally went out to an all blue screen.
    President:
  • 563 Answers
G'Day!
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need further assistance so that I can help you further.
Posted on Jul 11, 2009
Rca 32" lcd tv.vertical lines on entire screen,no pix.
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
www.youtube.com/watch?v=PWoz_-3OHIMJan 25, 2013 - Uploaded by Tampatec I have a LG 42PM4700-UB plasma tv that just went black. The red power .... I have a RCA 32 inch it has no sound or picture !Just a light blue ...
Sep 09, 2015 | RCA L32HD31 32 in. LCD HDTV
I have a Spectronics TV and the power is dead. No lights, no sound just nothing
Hello
Open your TV and check the protection fuse inside [on the power regulator board] is blown up or not. If blown up, repalce it with same type and ampearage. The ampere ratings can be noted on its edge rims. If the replaced fuse again blows Off, make sure that there is some short circuit with the components on that board.
This is the picture of the power supply board to your tv. There is no repair to it. Just replace it as card basis.2_8_2012_5_14_53_am.jpg
Feb 07, 2012 | Spectroniq PLTV3250 32 in. LCD TV
Intermittent red line on screen left side
To determine whether this line is a fault of the TV's or a fault of the signal source you have to do a simple test when the line appears on your screen. Please press the Menu button on your TV remote, and see how the line interacts with the menu. If the line goes over the menu then your TV's panel is faulty and will have to be replaced. This is covered by most manufacturer's warranties. If the line goes under the menu then you have to talk to your signal provider (cable, satellite, etc) to figure out what they are transmitting.
Jul 18, 2011 | Sharp LC-32SB24U 32 in. LCD TV
Black screen ecept for thin white line around all four side. Channel buton changes colors in various section of screen. On/ off button does not work
I found the solution on mine. To restate, I just saw a thin white border around a black screen. Pressing the channel up or down buttons changed the screen, in some kind of test mode to shades of gray, and red, green, and blue. I started finding a solution when I noticed when on one of the color screens, that the volume up or down buttons brought up a new menu for color intensity. Finally, I got back to the thin white border screen and pressed the arrow keys in the top half of the remote. Finally a TV screen and I pressed the enter key! Voila!
Mar 14, 2010 | Sylvania LC320SLX 32 in. LCD TV
Red thin line on left side of screen / black colours have a burnt red tinge over them. TV is 30 months old
If that line is permanently on the screen  - even when you are using the AV signal then the LCD panel is busted, no way to repair it. Try getting it replaced under warranty, it shouldn't have failed so soon
Oct 30, 2009 | Samsung LA32A450 32 in. HD-Ready LCD TV
No picture just a blue line across and its not the cable
You may take a strong flashlight and place it against the dark areas of the screen and look around the edge of the light. If you can see an image moving around, it is still being 'displayed' on the entire screen.
If its still there, it looks like an Inverter/CCFT problem. If the image is 'gone' or compressed into a single 'line' it may be the LCD controller (TCON) with a 'heat' or intermittent problem.
You may try a fan blowing on the vents on the TV to see it runs longer without going bad.
Feb 23, 2009 | Insignia IS-LCDTV32 32 in. Television
All my blacks are red
Something wrong with T-Con Board or connector problem between T-con & Main(LVDS)
Jan 27, 2009 | Samsung LN40A650A LCD TV
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
New vizeo 32" LCD TV -- black and white?
check to make sure that both are tuned to the same chanell.
Lou Margolis
Allied Electronics
loumargo@verizon.net
Dec 15, 2008 | Vizio L32 32 in. LCD HDTV
Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Jul 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Spectroniq PLTV3250 32 in. LCD TV Logo
142 people viewed this question
Top Spectroniq Televison & Video Experts
Jayesh Panchal
Jayesh Panchal
Steve Allison
Steve Allison
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
