Question about Garden
Cutting head will not stay on
Cutting head is not locked onto shaft
  • 33 Answers
If your twine cutting head spins off when started,you probably have a bad gear box (bearing went out)
Posted on Jul 12, 2009
Trimmer head will not stay connected to shaft
Should be reverse threaded so that the rotation tightens it. However it could also be missing a locking nut or pin.
Oct 15, 2015 | Garden
Trimmer head won't stay on
Use a piece of trimmer like in head. As you slide it on it will likely be tight and hard to come off
Oct 13, 2015 | Poulan/Weed Eater No. Te475 952711797 17"...
Troy built 635 bump head won't turn
When you say it wont turn, i assume you mean the engine is running but the head isn't turning.?? Check the drive shafts and the clutch. Does the cutting head turn by hand or has it locked solid.? If its locked then its a gear problem in the cutting head.
Aug 08, 2015 | Troy Garden
I have a L123 Husquravana brush cutter and I am looking for the lock nut that holds on the trimmer head. I am looking for the size to the lock bolt.
The trimmer head is not held on by a nut, the whole trimmer head is spun onto a 10mm male output shaft, to remove the trimmer head lock the geabox by inserting a 6mm pin through the top of the gearbox, there is a hole to take it, this will lock the drive disc, you can then turn the whole trimmer head clock wise ( left hand thread ) and remove the trimmer head. Parts are available for the trimmer head, it depends on which head you have, manual feed, or bump feed.
Nov 22, 2012 | Husqvarna 123/223L Brush Cutter Kit...
How do you keep the shaft from turning when working on it
If you're refering to working on the cutting head without the shaft turning then you should be able to lock the cutting head to remove it. There is a small hole in the top of the gear head that you need to put a small rod in to jam the head from turning.. this inturn will also stop the drive shaft from turning.
Sep 03, 2012 | Husqvarna 28cc Gas Line Trimmer
Homelite Mighty Lite 26CS Model21004D
Once you have the string wound onto the spool, place the spool onto the shaft and pull the strings out of the slots so that the string feeds through the holes without going through the slots. Good luck...Lee
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Cannot get agitator off shaft Hoover 550M washing machine
Had to cut agitator away leaving metal boss exposed will now use a puller to pull off drive shaft
Dec 22, 2009 | Washing Machines
How do I remove the head from a Husqvarna 25 R weeedeater so I can load the string? It is a tap'n'go trimmer.
The plate that the head screws onto has a hole that a small diameter, provided straight shaft tool sticks in to lock the plate. Then it's just a matter of turning the head counterclockwise to remove it. Of course I lost mine and had to find the right shaft diameter screwdriver to do the job.
Jun 03, 2009 | Husqvarna 28cc Gas Line Trimmer
Blades won't stay on mixer
if this is new then i would just take it back it may be faulty.
Oct 27, 2017 | Wolfgang Puck Food Mixers
The spindle (middle thingie) is broken
I don't know about the little lip you're referring to, but the central spindle that comes up from the base of our KitchenAid 12 cups food processor KFP750WH0 splintered and broke while we were using it. We ordered a replacement motor sleeve shaft part number KA8211849 from the Gourmet Depot for $4.95 plus $3.50 s/h. Removing the broken plastic sleeve shaft was the difficulty; it isn't glued or screwed on but somehow it didn't want to be pulled, pried, or cut off. With the help of our neighbor fix-it man and all four of us working at it with screwdrivers, we got the old broken part up and off. Pushing the new one onto the metal motor shaft was easy, and it was fixed!
Jan 16, 2008 | KitchenAid KFP750 Food Processor
Garden Logo
81 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
