Question about Admiral Refrigerators
The top freezer is warme 45 and motor keep running 24/7 no circle
  • tipoulbenz Jul 11, 2009
    there is no ice or frost and the fan and compresor arerunning. I did unplug it for 1 week
    President:
  • 1,136 Answers
Hi, I have to ask some uestioons so we can narrow this down. If you look inside the freezer, is there any frost or ice building up on the rear panel? Id the evaporator fan motor running inside the freezer?
If there is no ice or frost and the fan and compressor are running, try removing the rear inside freezer panel. Look at the evaporator coils and see if there is thin layer of frost covering the entire coil.
Please get back with me and let me know what you find out.
Thanks
Vic
Posted on Jul 11, 2009
Mitsubishi MR 560X. Top shelf of freezer not freezing food. Vents have been icing up. Fridge appears to be running too warm, around 11degrees Celsius. I have turned off fridge and defrosted it for 24...
You have lot your evaporator fan motor in the freezer that caused no air to circulate, this would also effect the refer section too. P# WR60X10185 if you need it, check to see if the fan remains running on high speed even when the freezer door is open for 3-5 minutes.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Dec 25, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Fan in Freezer portion not running, compressor works
The door switch, some fridges run the fan on door closed only.
Jul 10, 2013 | Frigidaire FRT17G4B Top Freezer...
@15 yr old GE top freezer fridge. Top freezer
check to see if an internal fan is fitted. This may have stopped/ burnt out. if fan is running try 24 hr defrost.
May 15, 2010 | GE GTS22KBP Top Freezer Refrigerator
Refridgerator and Freezer
Compressor may be warm but not running. What part is brand new? Would you like me to assist you? If yes please make sure your model number is correct. I'm waiting for your reply, Sea Breeze
Nov 19, 2009 | Whirlpool ER2MHKXPL 22.0 Cu. Ft. Freezer...
Freezer side cold fresh side not GE GSH22KGMD
Find the return air It can't come in if it can't get out. also if you were checking it with the freezer door open you will not feel the air. Just in case i have done that myself. if all air ducts are open and it's getting o I should be 20 in fresh food with the control on 9.
Sep 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Nov 20, 2008 | Kenmore 64802 Top Freezer Refrigerator
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Feb 07, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Jose Pino
steyr1
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
