Locks & Locksmithing Logo
rose dawson Posted on Jun 11, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ok i locked my keys in my safe ... as i didnt want anyone to find them and have access . So ive gone to open my safe tonight with usual code and it does nothing but beep for a good minute or so. HELP
Huseyin Huseyin
Level 3:
  • Master 3,469 Answers
  • Posted on Jun 11, 2015
Huseyin Huseyin
Master
Level 3:
Answers
3469
Questions
Helped
765848
Points
11197
You need to isolate it from the power somehow, perhaps remove the fuse for that socket or those in that room. After a while, if the battery backup is not fully charged , (hopefully,) the door should open. . Is there a keyholder who can open it with a backup key perhaps?
We did the same last year and were able to access the contents after a short wait. In regaid to why the code failed, a power cut, even a short one will cause the installed combination to be lost
5 Related Answers
A
Anonymous
  • Posted on Apr 27, 2009
SOURCE: I cannot open safe with the usual code.Safeguard electronic digit
To open a Safe International Digital Electronic Safe
User override key to open safe
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
c. To change code repeat step a.
Test your new code before closing safe.
David Shaub
  • 2994 Answers
  • Posted on Aug 07, 2009
SOURCE: micromark Electronic safe
Contact the manufacturer with the model and serial numbers. They CAN supply a default passcode number.
Anonymous
  • Posted on Oct 10, 2009
SOURCE: gordon item#45891 digital safe, lost code the door is open
there is red button on the inside of the door (hinge side) press this , then key in a new code
Anonymous
  • Posted on Apr 06, 2011
SOURCE: I have a Safewell Electronic
just **** a ****
Anonymous
  • Posted on May 14, 2011
SOURCE: I cannot open my Noble
I cannot open my Noble safe. I havent used it for 1 year, it has no battery and cant open it with my key. I cant remember the code, but i wont be able ti use it with no batteries.
What can i do
2answers
I have a safeplace safe and the battery dead, how can i open it?
Most such safes are supplied with an override key for such an eventuality, though the keyhole might not be obvious and some trim might have to be removed for access.
This type of safe is commonly used in hotel rooms and no hotel would equip themselves with safes there is no backdoor method of accessing as keys are often lost and codes forgotten...
How to open my kingavon safe 28 without key. Cannot open with code either
I have the Kinavon 28 safe, I have lost the keys and the batteries started to die, eventually the batteries I think have given up, I use to get all the three lights on, red, yellow green but now I'm only getting the yellow light on, there's no clicking as It usually did, has anyone any Ideas how I can access It or resolve this problem?
I Have a Suresafe 20ES and the battries have gone flat. How do I get the door open
There are two ways you can open this safe. First one is to give alternate power supply for which generally a devise is provided which I do not think you have the access to. Second Option is that you must have manual override keys. With this manual key you can open the safe and then change the batteries.
19helpful
2answers
I cannot open my Noble safe with the code I had. It seems that my code is gone and I don't find the key to open the safe. What can I do ? songa
What can i do
6helpful
Kingavon electronic safe 28
  1. The original factory code is 1-5-9 A (or B) to open the safe. There is usually an override key for your safe in case you have lost your code.
  2. Once the unit is open, you can reset the combination by pressing the red button, the yellow light will come on. Input a new code 3-8 numbers and then either the A or B button to finish the code.
  3. Test your new code several times before locking.
  4. If you don't have an over ride key, the first three digits of the serial number should be the key code.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Ive locked my spare keys in my safe and cant open it
Without the code or the keys, chances aren't good unless the lock is a simple wafer lock which could be picked easily. Try calling a local locksmith -- I can't pick locks over the internet and will not teach it for obvious reasons.
5helpful
2answers
Then:
Function code not working
well zarshad lets solve ur first issue MEMORY CARD.
so like u told dat uve set a password to protect ur memory card from unauthorised access right?but bro the password set on that is working perfectly fine. it will prompt u the password when u will insert that card into a MEMORY CARD READER SLOT( IN LAPTOPS,DESKTOPS ETC) and IN ANOTHER N73 OR N73ME fone.so dont worry abt the card password. u can access it but not on other device except ur N73ME.
and ur next issue. THE KEYPAD LOCK. LETS GO STEP BY STEP and confirm the same steps that im telling u,u make the changes in ur fone settings ok?so here we go:-
1.Goto ur fone menu and select the SETTINGS icon,where ever its located or where ever u moved it.
2. Select the option that says SECURITY with a lock in front of it.
3. Select the option that says PHONE AND SIM.
4. select the option that says AUTOLOCK PERIOD. By default it would say NONE.
5. When ull select this,it would say NONE and USER DEFINED. So select USER DEFINED.It would Say "Lock after (minutes)". Mention the number like 1 for 1minute or 2 for 2 minutes or whatever time u want ur fone to autolock it self "1 minute" veing the least time. u can't select the time in seconds.
6.Next it would ask u for the code. By default the code is 12345 IF u haven't changed it as per ur wish.IF u've changed 12345 to other number ull have to input that number vich would be a 5 digit number.
VOILA!!!!! uve set ur fone for autolock. and ull have to input that code everytime u want to access ur fone.NOBODY n i meant it NOBODY can access ur fone after this. IVe followed the same steps n ive set up my fone to lock itself in 1 minute.IF U WANT TO LOCK IT MORE EARLY MANUALLY,PRESS THE POWER BUTTON ONCE AND THEN SELECT THE OPTION "LOCK PHONE"
WHEN U SET UP THIS AFTER LOCKING UR FONE A KEYLOCK WOULD APPEAR ON THE SCREEN.
OK?so follow these simple steps n im very sure that ur issue would resolved
226helpful
11answers
Sandleford electronic safe es20
have just had the same problems if you had the key there is a red button inside the door to reset the code but obviously no key no red button I have the sandleford number to call 03 97750699 or try the factory pre set 159 A or B see how you go
Top Locks & Locksmithing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
