Uniden CEZ260 Corded Phone Logo
ALBERTA DORSEY Posted on Jun 11, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to program new phone numbers
Printable vertion
jkpearman
Level 2:
Habit-Forming:
  • Expert 90 Answers
  • Posted on Jun 11, 2015
jkpearman
Expert
Level 2:
Habit-Forming:
Answers
90
Questions
0
Helped
30717
Points
450
The manual is available here: www.uniden.com/pdf/CEZ260om.pdf. If you search google for "uniden cez260 corded phone manual" it is the first result.
You can find the instructions in the fourth column of text under "Storing a Name and Number in Memory"
Here is the text from that section, but I can't promise the copied text is accurate. Check the pdf at that address if anything doesn't work.
1. Press STORE. LOCATION? shows in the display.
2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location.
3. Press STORE again to con? rm the memory location. NOTE: Use Delete to erase existing memories or to correct errors.
4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. (The unit will not dial a phone number in this mode.) The cursor automatically moves to the text line for name entry.
5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The ? ashing cursor automatically moves to the next position or you may press LEFT or RIGHT to move the cursor to the next position.
6. Press STORE to save the name.
7. To enter another name and number in a di erent memory location, return to step 1 and repeat this process.
Storing a Pause in Memory
The REDIAL/PAUSE button has dual functionality and becomes a pause button when pressed in sequence after the STORE button. It is valid only when storing a number into memory locations. Use the REDIAL/PAUSE button to insert a pause when a delay is needed in an automatic dialing sequence (for example, when you must dial a 9 to get an outside line or when you enter codes to access your long distance company).
NOTE: A pause is 3 seconds in length and you can store more than one if a longer pause is needed. Changing a Stored Number Repeat the storage sequence under Storing A Name and Number in Memory, and press DELETE to delete the old number before entering the new number.
Erasing a Stored Name & Number
1. Press STORE.
2. Press the memory location (0 to 9 or quick call buttons A, B, or C) to be erased.
3. Press DELETE.
Copying Caller ID Memories to User Memory
1. Press LEFT or RIGHT to view the caller number and name you want to copy.
2. PressSTORE.
3. Press the memory location (0 to 9 or quick call buttons A, B, or C). The number ? ashes if there is a number already stored in that memory location.
4. Press STORE to enter Edit mode, and then pressSTORE again to edit the name. NOTE: Select a di erent memory location by using LEFT and RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C.
5. Press STORE to con? rm and save. Wait three seconds to exit.
NOTE: If the name you want to enter is longer than 12 characters, only the ? rst 12 characters will be copied into memory.
Storing a Redial Number to Memory
1. Press STORE.
2. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If a number is already stored in the memory location, it will appear on the display. Use LEFT and RIGHT to select a di erent location.
3. PressSTORE again to con? rm.
4. Press REDIAL/PAUSE, and then press STORE again.
5. Enter the name, if necessary, and then press STORE to con? rm.
Copying a Redial Number to Memory
1. Press REDIAL/PAUSE while on-hook. Redial number will display along with PICKUP PHONE.
2. Press STORE.
3. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If there is a number already stored in the memory location, it will appear on the display. Use the RIGHT or LEFT buttons to select a di erent location.
4. Press STORE twice.
5. Enter name, if necessary, and then press STORE again to con? rm and save.
Dialing Numbers Stored in Memory
1. Press DIAL.
2. Press a memory location button or use LEFT or RIGHT to scroll through stored memory locations to ? nd the desired number. The number in that memory location displays.
3. Press SPEAKER or pick up the handset to dial the displayed number.
OR
1. Lift the handset or press SPEAKER.
3. Press DIAL again to dial the stored number.
I already have quickbooks pro. but i need to validation code and this my email([email protected])
you must have a product key on the box or the cd satual some werealso you need to register the program to activat it on line. but if it is a tryal pack then you need to buy the full vertion
2answers
Windows 7 is not compatible with Teacher's Toolbox 4.0
you may have to upgrade to a newer vertion of teachers toolbox
Have microsoft office 2007 but cannot inout data into excel spreadsheet, keep requesting porduct key...thanks
if you are using a trial vertion then you may need to by the full vertion or enter the product key on the inside of the container that you got your cd in
I have panasonic kx-t7730. How to set the intercom name and number?
Changing the name and extension number can be done through system admin programming from a phone extension allowed by the class of service assigned to that extension by the phone system installer. Typically the attendant phone is allowed this ability. From the programming phone press **1234(1234 is the default password) to access programming. Once in programming dial 003 for extension numbering then press . Enter the current extension number of the phone you want to change followed by the new extension number then press . Lift the handset to end programming. Access programming again by pressing **1234. Dial 004 for extension name programming then press . Enter the new extension number you programmed then enter the name for the extension. Press then lift handset to end programming.
It is possible that your phone has not been assigned an extension number, in that case system installer programming would need to be accessed to assign the port an extension number. The port number the phone is connected to would have to be determined. This could require tracking the wiring back to where it is connected into the phone system. If this is the case I advise calling a qualified service technician.
Uniden DECT 6.0- Where can I get a printable instructional manual
DECT 6.0 isn't a model number, it's the generic name for the cordless technology in use. Uniden's manual download page is here. The phone model number number is on the rear or bottom of the base unit. Pick it from the list and you'll be able to download a replacement manual.
My computer had the full vertion when i got it but now its asking me for a product key and i carnt find it
To obtain a new product key for your Office program in the United States, call 1-800-936-5700 and speak to a Microsoft customer service representative. Outside of the United States, call the number that appears in the activation wizard.
When you call Microsoft for a new Office product key, have the following items available for the customer service representative:
· The product CD-ROM
· The computer on which you want to install Office
· The readable parts of your original product key (if available)
· The ProductID information in the registry
I can't hear any sound
Reload the the old manufacturing vertion .Go to your manufacturing web site type your model number and all infor what the ask and reload your original vertion.
We'd like to add "date stamp" to each picture taken with EX-Z57
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Upgarading my iphone
You can upgrade your iPhone's software by installing iTunes onto a PC and connecting to the computer. The iTunes program will offer to upgrade the software as soon as you connect.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
