Question about Photography
Someone recently gave me an old Pentax with new film. After 15 pictures, when I try to **** it, there is no resistance and the film does not advance. ?
  • Obertelli
    Obertelli May 11, 2010
    Which exact model? Are you sure it wasn't just a 12 exposure film cartridge? (You can often get a few extra frames).
  • 39 Answers
It can be 3 things: 1.- Film sprockets are broken. 2.- Film sproket's carriers in the camera is broken. 3.- Film sproket carrier's mechanics ate broken. Unloadeit in complete dark and you can touch if film is broken, that would be the best case scenario.
Posted on Jul 14, 2009
My Pentax ZX-7 (MX-7) mirror is stuck
This camera can be notorious for these types of film advance issues. The bad news is that a ZX-7 is probably not repairable. Good news is that there are many used Pentax bodies out there that will work with you lenses.
Dec 11, 2013 | Photography
Hello, I have not been using my Pentax zX5n for a while. Recently I decided to use it again and was surprised to discover that after loading a new batteries that it would not start. Actually after loading...
Have the old batteries leaked in the battery compartment ? Also, when you removed the previous film, did you set the camera into rewind mode ? If not, you have probably damaged the winding motor beyond economical repair.
May 08, 2017 | Pentax ZX-5 35mm SLR Camera
My pentax k1000 works great except for when I first load the film. Every time I first load the film, the rewind knob wont rotate when I snap pictures. Everything on the inside is intact and usually I have...
I'm not sure I see a problem here. There is enough slack in the film that the first few exposures can spool out of the canister without it turning. If in doubt, close the back and then _lightly_ turn the rewind crank to take up the slack. Don't force it, just turn it until you feel resistance. Then advance the film and see whether the rewind knob turns.
Feb 28, 2011 | Pentax K1000 35mm SLR Camera
My Pentax SPII shoots blank images
You can check the shutter without film in the camera. Remove the lens and open the film door. You will see the cloth curtains of the shutter in the center. Advance the film lever to **** the shutter and set the speed dial to a slower speed like 1/15. Hold the camera so it is aimed a a light source, (a window will do) and fire the shutter. You should see the light through the shutter for the time duration is is set to. (1/15). If you see the light source, repeat the process going up one speed setting until you reach 1/1000. If you see the shutter open and close as described, then try another roll. After you load the film and close the back door, make note of what the rewind knob is doing as you advance the film. It should spin counter-clockwise each time. That is a easy test to know that the film is traveling in the camera properly. Vary your exposures with the new roll at different speeds and f-stops. You should get exposures, but if not let us know.
Jan 31, 2010 | Olympus Stylus 850SW Digital Camera
Pentax SF10 Camera -- double exposure
If you press the film release button like you are going to rewind exposed film you may be able to activate the film advance lever to cock the camera so you can take another picture, and the film should stay on the first exposure allowing you to re - expose it. I would underexpose each image 1 F stop because.you are exposing the same film twice. Double exposures are always an iffy proposition and anything can happen. After the second exposure cocking the film advance should allow the film to advance once again. You might test this on the final pictures on a roll in case the camera won't start advancing the film after you try it. This way you won't blow a whole roll worth of pictures testing it.
Apr 12, 2009 | Pentax PZ-70 QD 35mm SLR Camera
Film won't advance
Pentax ME Super was one of my favorite camera, small and clean shutter release. But it has been about 25 years since it was manufactured. They happen to use rubber break within shutter unit and as any rubbers, it started to deteriorate and melt between the shutter-blades. This prevents the complete cycle of the shutter and jams the winding. You may be able to unjam the winding but eventually you have to overhaul the shutter unit. Overhaul charge is around $100 in US repair market. -James
Mar 31, 2009 | Pentax ME Super 35mm SLR Camera
Film wont advance although taking pics, and HELP keeps appearing
Search the internet (don't forget about specialized forums) for a well reviewed Sony/Minolta repair shop.
Dec 26, 2017 | Minolta Maxxum 400si 35mm SLR Camera
Film Advancer loose
Hi., rotate the rewinder clockwise until the film will tightened , hold the film rotator , observe the rewinder knob moving , it means the film are engage will. then shoot for favorite angle.
Feb 18, 2008 | Pentax ME Super 35mm SLR Camera
Film will not advance
Pressing the rewind button wind the film advance lever,if it is free It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Then your winding gears need cleaning
Jan 18, 2008 | Pentax ME Super 35mm SLR Camera
Pentax zx 50 35mm slr
Others here have suggested the problem lays with the plastic gear on the advancing motor beside the mirror.
This might cost $100 or so...?
Oct 22, 2007 | Pentax ZX-50 35mm SLR Camera
Photography Logo
56 people viewed this question
Top Photography Experts
TC CAMERA REPAIR.Com...
Marvin
Marvin
Are you a Photography Expert? Answer questions, earn points and help others
