Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool Imperial problems
If the load is held below about half it works fine, also seems sensitive to water level being to high. However, any load over that the machine refuses to agitate or spin and rinse. Is this a coupler problem or something else?
  • 213 Answers
Either a coupling problem or the gear case is bad. look at the couping if its not broken the the gear case is bad
Posted on Nov 20, 2007
Whilrpool imerial series washer making strange noise
The agitaor coupling or drive mechanism is stripped. You will have to pull the agitator up out of the machine to find which of the parts need to be replace. Most likely th agitator coupling.
Jan 27, 2010 | Washing Machines
Washing machine won't stop filling--is the WLC defective?
The 3 likeliest causes of your problem are:
  1. Bad pressure switch (water level control)-It may react to your straw but the range it finally kicks off is higher than the highest possible water level.
  2. Bad sensing line-The plastic tube may have a pinhole leak caused by abrasion while your suspension system was out of order or it may just leak out the air. Place a small screw operated hose clamp on the hose where it attaches to the pressure switch. Place a finger over one end of the plastic hose and blow in the other as you submerge the hose under water to check for leaks. Replace if necessary.
  3. Clogged reservoir at tub end of sensing line-clean out with thin blade screwdriver. Sometimes grease or undissolved detergent accumulates in this area and blocks the pressure from sending a proper signal.
One of the above three should resolve your problem. Obviously, replace the pressure switch as a last resort after checking steps 2 and 3.
Good Luck
Sep 21, 2009 | Amana ALW880WH Top Load Washer
Force Unleashed bonus objectives don't load or work
the game save may be corrupted. I know the game isnt terribly long so I would just clear the SWFU data and start over.
Apr 25, 2009 | Star Wars: The Force Unleashed for Xbox...
Whirlpool Duet GHW9400 Water Level Seems Too Low
Scott,
Believe me, if the water level were ever several inches above the glass, you'd know about it 'cause it would flood your laundry room. Seriously. See? That rubber door boot/seal is not water tight (like a submarine) when the door is closed and locked, it's water "resistant".
Front loaders often appear as though the level is low, but they are designed this way. The clothing actually tumbles through the water as opposed to soaking in water like a top loader.
All of that to say that you have nothing to be concerned about. Your water level is fine.
SG
p.s. If your water level switch had failed, as you suspected, the water level would be too high and leak out the door.
Apr 03, 2009 | Whirlpool GHW9400 Duet Washer
Imperial Deep Fryer won't light
The pilot should not lower on main valve opening, this is a dangerous situation and should be handled by a pro.
Aug 08, 2008 | Imperial Kitchen Appliances - Others
Whirlpool super capacity imperial
We have a drain issue it seems like. I would first check the drain hose to make sure that an air gap exists to prevent drain water siphoning into the machine and then run a rinse and spin empty to see if this helps. Second is to check spin speed and pump condition as these two can work together to create a problem similar to yours.
Apr 05, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool Imperial
With the machine off and empty, fill the softner bin with water only. Does the water level go down or stay the same.
Nov 28, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool imperial series 2 ultimate care washer
I had the same problem with this washer. It was the lid switch.
Apr 08, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
61 people viewed this question
Dan Webster
Dan Webster
Sal De
