PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Compaq Presario Laptop lost power
By MyEye on Nov 15, 2007
Model 1525 US working with battery and AC Power Supply Adaptor suddenly displayed message that battery was low and I should save work.
The external power supply was connected at the time.
The Power icon disappeared and the low battery icon appeared. I exited nicely. System shut down and will not turn on again without battery.
External Power Supply is good, reading nominal 18.5.
I have disassembled top cover palm rest and am looking at the little battery charger board in front of me. Could that be the problem or is there another circuit on board which would cause me to lose power with the supply connected. System is 5 years old.
Thanks in advance,
John K.
Comments:
Nov 17, 2007
- Thanks very much. I'm in the process of ordering one and also taking a look at the DC-DC converter on board. I wish schematics were available for the motherboard; it would make the job a lot easier!
Nov 19, 2007
- Battery Charger Board was just ordered
These are the numbers:
Compaq Presario Laptop 1525US
Serial Number: 9X2AKQFZ41FK
Same Problem
Nov 17, 2007
-   The power icon (a AC plug) mouseover popup on my wife's X1000 will say "On AC power" when the AC adapter is connected. However, it is really running off of the battery. The external inline converter is cold. The laptop will shutdown when the battery is depleted. When it is restarted it then really does run off of AC as the icon is the AC Plug with a lighting bolt-like overlay. The mouseover popup indicates the battery is charging and the % charged. The external converter gets hot to the touch. The bottom of the laptop is hotter while charging compared to when running off of the battery. Same issue is seen with a second battery.-   Guest
Best Solution
posted on Nov 15, 2007
Helpful)
tom19511
Rank: Guru
Rating: 85%, 2166 votes
the battery charger board, is what I would swap first.
Good luck, keep us posted.
Comments:
Nov 17, 2007
- What make and model laptop do you have. I will try to find a repair manual for you.
Was this helpful?
Yes
No
Solution #2
posted on Jan 05, 2009
Not Rated)
Alcatrazx
Rank: Wiz
Rating: 79%, 45 votes
I have the exact same problem this time with an ASUS A6KM laptop. When you press the power button on this laptop. Everything seems ok the hard disk starts up but nothing is displayed on screen. As soon as the ASUS bios logo is about to appear on the screen, the laptop shuts down. The same happens when the CD player button is pressed (as the laptop has a function to just play CD's off the CD drive without turning it on). The power supply seems fine it is pumping out the voltage it ought to. Has anyone got an idea of what this might be? People said its the motherboard and I find it hard to believe as these laptops are known for their reliability.
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area... (More)
Answer
what is the problem of my HP laptop is going to blink2x his display in screen?
Answer
My Gateway CX2724 will not install a fresh copy of XP on new Harddrive. HDD is a newly formatted,... (More)
Answer
My presario M2000 will not star orf come on. It has a new battery & power adapter.It gets... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
