Where is the lint catch in a Kenmore 3.1 front loading washer? I'm getting dog hair coated doorway!
  • 5,911 Answers
Check the rubber bellow (gray seal) around the door, first. Pull back the rubber folds and check the power portion. Hair and lint tend to collect in this area.
Next, check the drain pump reservoir. The link I'm providing below explains how:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
You should also check the drain lines to ensure they are not clogged or restricted as well. The drain line that leads from the bottom of the wash tub to the inlet side of the drain pump can be a common point where debris can become clogged too. If this does not correct the problem, or if you have questions, please let me know. I hope this helps you.
Posted on Jul 11, 2009
LG WT4801CW HE top load washer poor performance.
I think you will find that hair and lint is much more effectively removed in a dryer.
Mar 23, 2017 | LG WT4801CW 3.7 cu. ft. top load washer
Model Kenmore 48102700 front loading washing machine. Drain is clogged. How do you get to water pump filter?
Remove the metal panel below the door... should be 3-4 screws. Once removed, you'll see the pump which contains a clean out plug on the front. Just twist it out and you'll find the screen, a bunch of lint, maybe a sock or two, and maybe some loose change. The only trick is catching the residual water that will come out of the pump when you remove the clean out plug. Try a shallow baking pan or something similar to catch the water. Assembly is the reverse of what you just did.
Good luck.
Jan 17, 2011 | Kenmore Front Load Washer
I just did a load of dog blankets, everything washed nicely, cleaned out the hair,put another load in of clothes, pushed the power button, heard a beep, pushed start and nothing happens.
Remove bottom panel.0da3616.jpg Get dog hair out of pump housing.a18b640.jpg
Tech sheet will be on that panel or behind that white box to the left.385ce31.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 22, 2010 | Maytag EPIC MFW9700S Front Load Washer
UE Error, maching will not spin the clothes dry. Tried all regular methods for resetting, moving around the load in the machine etc. Nothing works
Remove the front cover at the bottom of the washer. Your drain hose and/or drain may be filled with sediment. I just cleaned mine and it fixed my no spin problem......also directions for doing so are in your manual. I used a large dog bowl to catch the water. If no water comes out of the drain hose after you unscrew the cap, squeeze it and see if gook comes out. Then remove the other cap (use a coin) and pull it out. Mine had years of dog hair, sand, coins in it. After I cleaned them, replaced them, spinning returned.
Mar 27, 2010 | LG WM-2277HW Front Load Washer
Where do i find the filters on a front load kenmore he2 i believe the filter is clogged with dog hair but i do not know where to find them and i cant find my manual the washer will wash but not drain all...
Front lower panel should have three bolts near the floor. Remove those and panel should slide down. There you will find a plug. once you unscrew it water will pour out, be ready.
Feb 11, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore smartwash quiet pak 9 is leaking
The lint is likely from the drum seal rubbing over time.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 07, 2009 | Kenmore Elite 45986 Front Load Washer
Frigidaire Front Load GLTF2940 full of pet hair
Why dont you shake out the maximm hair before loading into machine?
Apr 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
Dirt and Lint on all my clothes
You can go to www.shop.washermd.com and there is a downloadable tutorial for removing the agitator. You also may need to replace the agitator dogs. Dave
Mar 03, 2009 | Kenmore 24032\24036 Top Load Washer
Is there a drain filter in the washer. we have lots of dogs and the washer seems to be taking longer for the cycles and maybe the hair is blocking the drainage from the clothes
yes there is a filter in the drain pump. remove the lower front panel and then you will see the pump.
take off the round cover and that is the screen to the pump. with what you have said it is probably plugged with lint and other stuff.
the pump will have water in it so be ready with a towel or a pan to catch the extra water. then whe you have the screen out, clean it and it should drain and work better.
the round screen is about 3 inches in diameter with a flat "handle" on the front of it. you cant miss it so take it apart and you can fix this yourself.
good luck, but you wont need luck, just a towel. about 1/2 a gallon of water.
Jan 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE 4T
HE 4 front load remove bottom panel 3 screws once remove now you have access to pump get towels and bucket oper lint filter and remove debris from inside ,,,,, and that its F2 long drain,,,,,,
Oct 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
paul
paul
