Not used it for a while. Turn it on. Seems to work fine, play back all fine. But in photo mode the screen is flickering
Could be part of the ribbon cable that feeds from the lcd to the main board has either dislodged or got corroded and is causing a bad connection.if you are brave enough to check always remove the battery first as this will prevent damage to circuitry.if the cable seems fine then it is more likely to be a sensor issue.
