Question about LaCie Computers & Internet
Lacie LaCinema Black Max does not get any channels when doing a channel scan on a cable network. No clue why: apparently does the scan, but does not get any channel.
The Black Max to my knowledge is designed for digital terrestial broadcast reception only. Hooked up to a compatible antenna, it will receive those signals, but will not work when hooked up to basic cable.
Posted on Nov 07, 2009
We have a jvc tv with built in freeview ; yesterday we got the message on the screen pr list empty and now are stuck with 5 channels and no freeview ; how do we sort
What service company do you have for your TV? Is it dish network or direct tv etc. You can do a channel scan once you verify the service company. A cable service provider will only provide 99 channel to scan/sort while a satellite service provider will provide you more channels to sort/scan.
Aug 23, 2010 | JVC GD-V4211PCE 42 in. Plasma Television
Max tv is mising in my starview2
Sometimes cable operators delete certain channels if they channel guys increase the broadcasting charges. It can also be that they have changed the broadcasting frequency that will push the channel to a different number. Scroll through all the channels to see if you can find it. Otherwise scan for channels again to see if iit can find the channel. If that does not resolve the issue kindly contact your cable operator so that he can clarify whats the problem with that particular channel.
Sai.
Apr 25, 2010 | StarTech.com StarView SV431USB 4-port KVM...
LaCie LaCinema Classic restore
Take all the files off it and reformat in FAT 32
Jan 13, 2010 | Computers & Internet
Am loseing channels every time i scan the tv some channels come correctly others apparently havent signal orignally all local channells came in perfectly now a couple channells come in perfectly when...
Depending on the signal strength of those channels on the days you do the scan your tv may decide that it is not a good enough signal for it to even bother programming into your normal channel list.
The weather will honestly have a lot to do with pulling in over-the-air broadcasts.
Nov 04, 2009 | Vizio L32 32 in. LCD HDTV
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
I can't scan DTV channels on my vizio 52''
do you have antenna or cable? if you have antena hook directly to the coax, go to menu, TV, tuner and pick antenna and scan. If you have cable hook directly to your coax repeat the previous step but pick cable instead of antenna. Notice if you have a cable box, you will not need to scan for channel since it will be on channel 3, 4 or any other input you may use.
Jun 20, 2009 | Vizio L32 32 in. LCD HDTV
What is the code for eurovox max v box for 10th june 2009
its not the codes that have changed its the channel frequencies, do :- menu installation manual scan down frequency ???.??? network scan - enable ok once the box has scanned, search at the end of your original channels, they should be there
Jun 10, 2009 | StarTech.com StarView SV211K 2-port KVM...
I just hooked up a Scott Television as a replacement for an RCA. I use Dish Network. Problem: TV screen is blank except for the words "Please scan channels." What should I do to "scan...
Go into your menu on your tv and select channel search. Make sure your cable and cords are firmly attached them start the channel search.
May 09, 2009 | Televison & Video
Element Electronics FLX2211B 22 in. LCD TV will reset every time
I have run into the same problem with a different model (32 inch from Circuit City). You may have found that there is almost no support from the co or web. I do not have an official solution but have some work arounds that have done the job for me.
WA#1 = after a channel scan tune to a HD/digital channel before you turn the set off. You need to do this each time for several times, because the set when turned on to a regular cable or analog station will default to skip all channels. After several times the set should remember your channels.
WA#2 = after a channel scan, go to the skip channel section of the menu, and if your remote has the colored buttons on the bottom scroll through the channels using the red and green (up and down on this menu) buttons. This apparently helps the set remember not to skip your scanned channels.
These are not glamorous solutions but appear to trick the TV into not re-setting the skip function for the channels.
Best of luck.
May 02, 2009 | Element Electronics FLX2211B 22 in. LCD TV
Computers & Internet Logo
222 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
