Question about Brother Office Equipment & Supplies
Brother fax trouble installing ribbon
Hi i have a problem i bought a fax machine and i don't have the software that comes with it and i don't know how to install i. My question is how do i get it to work or where can i get a new software?
Sincerally:
Noemi Salazar
Posted on Apr 04, 2008
How do you load a new ink cartridge?
Replacing the Print Cartridge
1 Open the front cover, and then open the top cover by pressing the blue levers on both sides of the top cover.
2 Remove the old print cartridge containing the used ribbon and dispose of it.
3 Remove the plastic stopper from the new print cartridge.
Note You can reuse the print cartridge until it breaks. If you purchased refill ribbons, follow the instructions that came with them.
4 Turn the black spool on the right clockwise to tighten the ribbon as shown.
5 Install the new print cartridge by inserting the recessed first, and then placing
the cartridge into its four holders.
6 Press down on both sides of the top cover to close it securely.
7 Close the front cover.
Brother Customer Service at 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Vertical Black Lines When Receiving
The sender's scanner may be dirty. Ask the sender to make a copy to see if the
problem is with the sending machine. Try receiving from another fax machine.
If the problem continues, call Brother Customer Service at 1-800-284-4329
You can save money by purchasing the 2-PK Refill Ribbon Rolls (PC302RF).
Installation instructions will be included. If you handle the print cartridge (frame)
carefully, you can reuse it until it breaks.
Jan 17, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
How do you install ribbon on brother 575 fax
On the link below on page 12-9 under troubleshooting is the directions on how to change the ribbon. I hope you like the fax because it is the same one I have.
http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000239/T8_UG_US_1.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 19, 2010 | Office Equipment & Supplies
Reuse print cartridge
throw away the used ribbon cartridge and install a new ribbon cartridge the part number is PC301 and office depot probably carries it ... the cost is about $12.00 to $15.00 contact me for more info
Jun 04, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother 685MC fax machine and when a fax is received the ribbon comes out with the paper. we have changed ribbons but it still happens
Possibly something is stuck in the unit. Remove ribbon and inspect, Also be sure rollers are clean and not torn.
Hope this is helpful.
Dec 28, 2009 | Brother Office Equipment & Supplies
Brother fax 575. need oem manual
Look on pages 12-9 thru 12-11 in this link to Brother for your Fax 575 for ribbon / cartridge installation instructions.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_FAX_575_EN_75.PDF
Nov 11, 2009 | Office Equipment & Supplies
Can I reset the used ribbon to recieve a fax ready to print
You can rewind the ribbon. But the areas that has ben transferred from past fax's will be blank.
Jan 28, 2009 | Brother FAX-575 Plain Paper Thermal
Fax copies come in too light to read
I don't want to be 1 of them to say is it a generic ribbon. Ribbon transfer fax's are touch ie on melting the print on the ribbon on to the paper. tried selling the ginaric ribbons did not work well.
If it is a brother ribbon then the blue latch levers my be creaked if the print is only on 1 1/2 of the paper.
hope this helps
Dec 08, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Print Fax Confirmation
Press MENU button, then 5 on the numbers keypad. you should be able to scroll through a list using the up and down buttons. #1 is the HELP LIST, #2 is AUTO DIAL, #3 is FAX ACTIVITY which shows LAST INCOMING AND OUTGOING faxes,#4 TRANSMISSION,prints a TRANSMISSION VERIFICATION REPORT of the last transmission. #5 USER SETTINGS lists your setting. To select your report, select the REPORT NUMBER, press SET, then START, to print
Jun 23, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Brother Intellifax 1270e
Make sure ribbon is installed correctly. Also check inside the tray area to see if the rubber roller and or the rubber separator pad is dislodged. Obviously not worth repairing unless under warranty.
Jul 09, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
70 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
