Question about Toshiba Satellite Pro U400-S1001V Notebook
I am unable to listen through my headset connecting through my laptop. it was working fine a day before, suddenly some problem occured
    Problem Solver:
  • 15 Answers
Make sure that you have to headset plugged in before you start the program you're using. Be sure to set te headset as the defult audio device for the program as well.
If this doesn't resole the issue, checking for driver updates, and/or uninstalling and re-installing the drivers usually works.
Posted on Jul 11, 2009
Why isn't my 1 day old headset not working?
If your headset uses batteries, check and make sure that they are installed correctly and still have a good charge. Make sure that the device that you are listening to with your headphones is configured to be used with the headphones. Make sure your plug connection is good and not damaged. If everything looks good, return the headset back to where you purchased them and ask them that you have a defective headset. Hope this helps.
Mar 07, 2014 | Radio Communications
Unable to listen music in Nokia BH 108
Hi! The Nokia BH 108 headset does not have the A2DP function (advanced audio distribution profile). However, if you are using NOKIA (symbian) non-windows phone, you can play music since the phone bypass the said restriction. You may want to try other bluetooth headsets that has A2DP function so you can enjoy the musics from your headset.
Thanks.
May 06, 2013 | Sony Xperia miro ST23i Smartphone -...
Headset not working
Did you try to check if the same issue occurs with a different headset?
• Do you remember making any software/hardware changes after which the issue started?
I would suggest you to make sure that you have latest compatible and updated drivers installed for the sound device on the computer. Microsoft will perform a free diagnostic scan and fix with three easy clicks. CLICK HERE
Jun 15, 2012 | Computers & Internet
Can i use my jb-th130 to chat, record, & listen to songs using my laptop ?
Yup that is possible as long as your Laptop is Bluetooth Capable that will work on your Laptop make sure that the Laptop Bluetooth Settings is set to be detected by other devices in the Bluetooth Settings.
Have a nice day.
mvincentc
Jul 25, 2011 | Jwin BLUETOOTH HEADSET Wireless Headset
I recently bought Nokia BH-503 headset.It functioned normally for few days with my iPod 4G.But today suddenly when I switched it on the headset started blinking blue light without even pairing with my iPod...
I'm facing the same **** with Nokia bh-503 it worked with my dell inspiron n5010 for few days but now it says pairing failed
this is really ******* waste of money..........
Jul 15, 2011 | Nokia BH-503 Bluetooth Headset
Bluetooth headset will not pair up with my LG DARE Phone, My phone trys to add it, but it cannot find the device to connect
Had the same problem. Paired fine with multiple devices (headset, computer, auto.) Then all of sudden BT will not connect. Cannot re-pair (unable to find device(s)). Had 1st phone replaced. Within about 6 months, the 2nd Dare did the same thing.
Oct 25, 2010 | Cellular Innovations HFBLU-CX1 Wireless...
Nokia BH-213 unable to Pired with Nokia E-63,it stopped suddenly
I also experienced the same problem. After trial and error I realized that the bluetooth device needs to be reset to fix this issue.You may reset the bluetooth device by deleting the pairings from the headset or reseting the headset. Switch off the headset, and press and hold the multifunction key for over 8 seconds. Start pairing the device again. It should work fine now with default passkey 0000
May 03, 2010 | Nokia Bluetooth-Headset BH-213 2600...
Unable to pair LG GM200 bluetooth 2.0 A2DP with Plantronics Pulsar 260. Error: "Request Failed" Please help in connecting this two devices
Each pair of BT enabled phone and headset is a particular world. I don't have the Plantronics, but my LG phone pairs fine with my Lubix stereo headsets. I'll tell you how I managed to pair them: I put my headsets in pairing mode. Then, on my phone, I go to 'Connectivity > Bluetooth > Device list > Options > New'. If my bluetooth stack is off I'm prompted to turn it on. It starts to search for devices, and comes up with my BT headsets' name, I press 'Pair', it prompts me for the pairing code. I enter '0000' (the same code for your Plantronics' headsets, by the way) and Ok. Then, back to the Device list, I select the BT headsets and go to 'Options > Connect'. I'm good to go. After listening to music, I use to go again to 'Connectivity > Bluetooth > Device list', select the headsets and press 'Options > Disconnect'.
Hope it works for you.
Cheers! Carlos
Apr 18, 2010 | LG GM200 Cell Phone
My Headset and USB cable don't work any more (LG KP500)
This could be either a hardware problem of software.
Try this and see if this works - visit http://www.lge.com/uk/support/index.jsp which is LG's support site and download the software for your network and see if this reboots the handset.
Failling that I would recommend booking it in for repair at lgrepair.co.uk or visiting your local CPW for a free repair.
May 07, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Toshiba Satellite Pro U400-S1001V Notebook Logo
60 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
