Question about Emerson EWC1304 13 in. TV/VCR Combo
How do I get my Emerson EWC1304 to work on an antenna?
I have tired 3 different Antenna in several rooms of my house with no reception not 1 channel
4 Suggested Answers
SOURCE:
ebackhus
  • 31 Answers
SOURCE: HOW DO I SWITCH FROM CATV TO REGULAR ANTENNA IN THE MENU?
In the Setup menu there is an option to specify if you use an antenna or cable. Just switch it to antenna.
Posted on Jun 03, 2008
intower18
  • 957 Answers
SOURCE: I need the remote control code for emerson EWC1304
Hi, These are the codes for your emerson EWC1304.
1264, 2132, 3131
I hope these codes will work for you.
Best regards,
Posted on Jun 24, 2011
SOURCE: what buttons do i press to add/delete channels on
Channel button back to menu from menu toggle down to channel setup. TV has to set up all the channels then you should be able to
go to all channels available for your cable.
Channels will have to be set every time you unplug your TV
Universal remotes are available at Walmart for $10 and the Goodwill
store sometimes has some remotes
Carole
Posted on Dec 11, 2012
I have no cable i get all channels excep CBS in chicago tried scanning no luck
Amazon has a great antenna that can bring in stations from as far as 150 miles away (terrain is a factor). Do not get these Window or Wall antennas as they are junk, just an outdoor type. I use one indoors, in my viewing room, however it can be mounted in the attic. The unit is a VILSO product, comes with a rotator, antenna booster, 50Ft cable, weatherproof antenna, control box and a hand remote, all for under $40.00. Check it out.
Jan 14, 2018 | Televison & Video
Antenna hook up
If you are using an indoor Antenna:
1- the most probable reason would be the location of the antenna and TV in an area where the reception is very low. Indoors all houses are affected by the running electrical circuits which in turn generate magnetic field that together with the structure of the house obstruct or weaken the wave signals of wireless and TV reception. Also this issue may be aggravated by the vicinity you are live in. Where you are living may not have the optimum reception from some services including TV signals. Your best bet is to try moving the (Indoor) antenna closer to the outside (such as windows, or better to a balcony) and try all four directions of the house.
2- One other possibility, is the antenna jack being disconnected from one of its wires (or a de-solder) at an internal part of its circuit). This problem can be detected by trying another antenna that is working good when used with another TV (and preferably at a different location) thus testing for the possible weak signal at the same time.
3- The last possible issue is the antenna receptacle built onto the Tv set. This may have a problem of some element of it disconnected internally on the board or de-soldered..
If the Antenna is external, all the above points are still valid, but the probability is higher, for some hidden disconnection on the receptacle, the antenna plug or at the connection of the co-axial cable with the external antenna. (Once I found a co-axial cable with disconnections of its central copper wire within the protective insulating coat- probably due to defects in the plastic coat that had microscopic holes that allowed air and humidity into the central wire and caused it to corrode and have those discontinuities)..
Jul 22, 2013 | Symphonic Televison & Video
Emerson rp 6247 radio AM stations does not come in clear
Try moving the telescopic antenna around in different directions until you get a clear reception. If that doesn't work, try moving the whole unit (radio) to another location. Make sure you are using the tuning knob to switch between stations. Moving it to a different location may be the best thing because the radio antenna may be received in frequency waves from another electronic device (i.e. a television set, another radio or in microwave) which is causing a reception to be poor.
Mar 21, 2011 | Emerson RP6247S FM/Weather/AM/TV Radio
I get bad reception with my TP-Link PCIe Wifi Card! What can i do?
Often times the antennae on these routers come loose. Ensure that the antennae are firmly plugged in.
Try also changing the channel. Routers have 11 to 13 possible channels and most default to 1 6 or 11. Try a different number to reduce interference.
Physical construction of your house can hinder wifi reception. This is often subjective and your best bet would be to move the router around the room or into a different room if possible.
Feb 28, 2011 | TP-LINK 11b/g Wireless Adapter
When I press Weather/Snooze the radio emitts a high pitch sound like a whistling. I have the radio set to voice, I have verified the channel 162.4750 for my area. I have a scanner tuned to that same...
Solution #1
Some counties have two frequency channels. check this URL address to see if you have another frequency channel for your area- http://www.nws.noaa.gov/nwr/indexnw.htm. If you do, try the other frequency channel for your area.
Solution #2
You may be receiving a poor reception quality because of where the radio is located or the antenna's positioning. First play with the antenna until you get a better reception. If this doesn't help, try moving it to a location near a window or outside room. If this doesn't help, you may have to buy an external antenna from an electronics store and hook it up to your radio. If you still have your WR-100 Owner's Manual, they have a page in there for reception (page 12), and it lists in there their suggested weather radio antenna.
Solution #3
It may not be anything you've done at all. It could be the weather station's transmitter itself. May you should call your local NWS office and plea your case to them.
Sep 13, 2010 | Midland WR-100 Weather/RDS Radio
Improve reception
HI there,
Well Yes you can improve the reception, please follow the below steps -
Improve FM Radio Reception -
1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
Improve AM Reception -
1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
3. Plug the radio into a different AC outlet.
4. Move the radio closer to a window.
5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
Good Luck!!
Thanks
Dec 29, 2009 | RCA RP5430 Clock Radio
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
VIORE PLC7V95 7'' portable TV, cant get channels when scan
I notice that on mine, the positioning of the included tv antenna is very, very, very finicky. I also don't know how to "add" a new channel other than to hook it to the big house antenna and pick "re-scan" (or auto-scan or whatever it's called).
So I think your best bet is to pick a better antenna or know that even the tiniest fiddling with the antenna makes a diff. Sometimes, I even have the antenna horizontal (using the magnet) to get the good reception on a given channel. Seems like a hassle except that what should I expect from a tiny antenna....
Jun 15, 2009 | Televison & Video
Off air antenna hook up
You probably have to set the tv to run on the input jacks your antenna is plugged in to. In other words these newer tv's have 2 or 3 inputs and they only run on the input it is set on, if not the right one you must change the setting. On mine there is a button next to the on/off button on the set which is inputs, keep pressing that button and it cycles through inputs till you get the right one. When tv first comes on it flashes the name of the current input on the screen--think they all do that. If input is hdmi, it refers to the hdmi socket, if composit (I think) then it refers to the rca jacks that are red, white, yellow, may be more than one of either. In this way you could have cable on one input, a video player on another, and cable on still another by switching desired input. I use a UHF antenna but it didn't work till I got the right input and then searched for stations studying the menu for station setup, have to set up the stations first, it will configure settings for each station, and have it do that before you can expect to find and receive stations. With correct input you should get a blue screen or something with printing if input is right, click your menu button and will see the menu and then find where to configure stations setup, otherwise it is totally black and nothing happens, nothing responds, that's the wrong input.
Jan 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Emerson EWC1304 13 in. TV/VCR Combo Logo
154 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
