I would check for abroken or impeeded water pump
propeller
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
Based on your description, there is a possibility that you have an item caught in between the stainless steel spin basket and the plastic outer tub. Use a bright flashlight and check the inner spin basket holes for an item such as a screw or nail (or underwire) that could be sticking through one of the holes in that spin basket and protruding down into the tub. If you find an item in that area, then removing it may fix your problem.
If necessary, shine the light through the holes in the spin basket to try to find the item that is making the rubbing noise. Check the bottom of that tub to see if you can find the item. Pull back the inner lip of that rubber door but and check for an item that could be stuck in that area.
You can pull the drain pump filter and clean it as shown in the image below. That procedure is also in your owner's manual. Here is a link for the full owner's manual in case you need it:
Owner's Manual
. An item stuck in that drain pump can also make a loud grinding noise even though we are assuming that you have an item stuck between the spin basket and the outer plastic tub at this time. It is worth it to clean out that pump filter and maximize the flow of drain water in the washer. Check that pump area for any debris or foreign objects (coins).
Pull that dispenser drawer out and check the outlet of that component for an item that could have slipped into and through that dispenser drawer area.
Hopefully you will find the cause of that grinding noise using the tips described above. If not, you may need to have a service technician examine the washer. If you want to go further on your own, you can
unplug the washer
and follow the steps shown in this video to disassemble the washer and check further for the cause of that problem:
LG Washer Disassembly
. Keep in mind that the front door boot seal is held on by strong spring clamps. It is not that difficult to remove the spring clamps but they are challenging to re-install without the use of some special tools that a technician carries. If you need further help with this problem, reply with additional details and we will assist you further.
If you get to the point where you need to have a service technician examine and repair the washer, you can schedule service through this link:
Sears Home Services
LG Washing Machine Makes Grinding Noise ShopYourWay
