Question about Cell Phones
Phone in ''Car Kit Mode''
My LG VX9800 phone is in the ''Car Kit Mode'' and I cannot make or receive calls. I can only send and receive email. My battery is also not charging.
Cannot receive or send calls. screen says CAR
OK obviously your phone is set on a sertain setting try contacting your provider for more help.
Jul 07, 2010 | LG VX5300 Cellular Phone
Lg vx8300 verizon says car kit display have no
Car kit mode means one of two things, first it could have a piece of lint or paper stuck in the charge port making it think there is a car kit plugged in, or second it could be that some moisture got into the port and its giving a indication that something is plugged in. and thats why you're not getting any sound. There is no specific setting to turn on or off 'car kit' mode you can use a paper clip or something and mess with the port a little bit to see if 'car kit' goes away or replace phone
Jun 23, 2010 | LG VX8300 Cellular Phone
VX 9800 wont send or recieve calls or anything
Take the battery out of your phone with the power still on then try to make a call once you get it started back up again. If that doesn't work then Call your phone company. It's a software issue. Hope i've helped you out, sorry your having trouble with it!!!
Mar 19, 2009 | LG VX9800 Cellular Phone
Hard Reset
This is the answer you are looking for. It's found:
http://www.mobile-files.com/forum/archive/index.php/t-42262.html
According to your phone not turning on, have you tried detaching the battery and putting it back on?
Hope it works!!
Apr 15, 2008 | LG VX9800 Cellular Phone
"use genuine battery" message
Because you are using a battery with more mAH your phone is not getting it. Have you got the same from LG, if so ask them for compatible battery. If not don't try such things. Better you get two batteries of lower mAH.
Feb 09, 2008 | LG VX9800 Cellular Phone
Car kit setting removal
"car kit" usually means the phone got wet...
unfortunately there is no way to fix it...
Jan 31, 2008 | LG VX9800 Cellular Phone
New phone wont wrok correctly
take the battery out and put it back in. Hope that works.
Dec 06, 2007 | LG VX9800 Cellular Phone
Dropped it into sink
was there water in the sink at the time?
if so check the connections on the base if there is green corrosion on it the the damage is done you will have to find someone who will repair water damaged phones.
If no water and just the drop that caused the prob then try removing the battery while the phone is still turned on this may shock it back
Nov 17, 2007 | LG VX9800 Cellular Phone
Says Car Kit on phone but has never had a car kit hooked up to it
A clarification on solution #1: Try pressing the tip of the knife (I used the end of a nail file) onto the lower right hand side of the charger area. That's what got it for me. If that doesn't work, try other parts of the end...
Aug 16, 2007 | LG VX5300 Cellular Phone
Cell Phones Logo
139 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
