Question about Toro Lawn Mower With Toro Power Tools
My toro recyclers self propel drive wont engage. belt and pully run and turn but wheels wont.is it the gearbox itself??
    Problem Solver:
  • 7 Answers
Most likley it is the gear box has failed but first take one of the wheels of to make sure that the plastic teeth on the weels didnt go bad (unlikley but wishfull thinking)
Posted on Jul 13, 2009
Selfpropelled portion stopped working, replaced broken belt,have correct p/n for new belt,belt is slack ,self propelled not working
There should be 3 pulleys one on the motor on top of the blade, one on the axle for the wheels and one that goes to your cable to engage that pully and tighten the belt, take the cover off that hides the axle and pull your handle for the self propell and see if its tighting, some mowers have a little adjuster to tighten the cable on the self propell handle or even on the cable itself, did you make sure to run the belt between the guides over the blade, let me know what you find so we can further help
May 15, 2016 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
20332 recycler will not self propel. Brand new out of the box.
Check the drive belt from the pully around the shaft to the drive gear. It may be off the pully. Not a big deal just put it back on.
Oct 29, 2015 | Toro Garden
How do you tighten or loosen a belt on lawn boy self propel mower? Where is the tension pulley bolt located to tighten?
most self propelled mowers engage an arm to put the gearbox into drive so it may not be a case of loosening the drive belt
May 06, 2015 | Garden
My toro 20624 lost self-propelling after the blade hit a baseball
check for the belt being off pully under lawnmower
Sep 16, 2014 | Garden
I have a toro commercial self propelled, engine stops when I engage the self propelled. I t runs until then. What can I do to solve this problem?
Regularly check the wheel-drive belt on a self-propelled mower for wear and tightness .... "Affected engines may run rough, stall or bog down under load,"
Jul 22, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 6.5 self propelled Mower - Self Propell won't engage
see if the lever going to the gearbox is cracked or broken. there is a gear inside the box that has a pin going thru the shaft that may have broken but usually it is external. these mowers have a plastic lever to put the transmission lever in gear if the cable is overtightened they wont hold up.if it cracks it leaves practially no tension on the engagment system
Jul 17, 2009 | Garden
Self-propelled feature runs slow and won't pull as it should!
Check the belt tension. There is a spring that holds the tension and connects the gearbox to the mower deck. If it has slipped off the belt will not be tightened properly.
Hope this helps.
May 05, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 20016 self propel
If you take the wheels off and remove the belt from the small pulley on the the front axle underneath the pulley you should see a small transmission. You usually can split this unit in half . You will see two gears and sometimes one plastic and one metal. The plastic one is usually the culprit. Hope this will help you out. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
628 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
