Have 2 sets, TDX01930B, TDX02611C. tried to play DVD in 26". intro ran about three minutes, screen went blank. now remote will only activate volume. also,now, on 19" remote will only activate volume. can not turn on or off either set with remote.
    President:
  • 563 Answers
G'Day!
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Both of your TVss will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TVs will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TVs at no charge as well.
If the TVs are no longer in warranty, it will likely cost a minimum of $150 parts and labor per set. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need further assistance so that I can help you further.
Posted on Jul 11, 2009
TV audio output vastly different for satellite feed versus DVD feed. Why?
It is possible there are separate sound level functions for the DVD player, the tv and the satellite box, try the different remotes for each by unlocking the volume control on the satellite remote until you get them close or use the device specific remote volume controls. I would also try and use HDMI if available for the DVD instead of composite. If the volume controls are different it will show on the tv, might also go through all audio settings for each device. Some devices are pre-amped or send out strong sound signals while others are line level outputs designed to be amped by the output device, in this case your tv I believe. The HDMI vs stereo audio that goes with composite may be the cause or it could be in the settings of the device. Worst case is to remember to drop volume before you switch back so you don't ruin speakers.
Jan 25, 2015 | Televison & Video
I have the sony portable dvd player and the screen went blank and it says "line in" and it wont play any disk
Look on the right side of the unit for a switch that says line select - make sure it's in the "out" setting.
Oct 04, 2009 | Sony DVP-FX820 DVD Player
Unable to retrieve picture on TV
when the screen becomes snowy, it means that something in the cable box is being overheated. what you should do is take a small desk fan and hold it beside the cable box. this has happened many times when my family has played on their xbox 360, and the desk fan solved this problem. i hope that this helps!
Jun 12, 2009 | Televison & Video
Hi, The quetiopn is about SONY DVD home theatre system DAV-HDZ235. For some reason I have big black box on a TV screen at time DVD playing. The picture appears and box dissapears when I pushong volume on...
Thanks for giving me the opportunity to help. Sounds like you are inadvertently activating P.I.P (picture in picture) with your remote. Perhaps the P.I.P button is next to the volume control. The black box you mention, is a blank channel. That means the way you have your cable box set up, there is no signal coming in to that p.i.p. tuner. Press the P.I.P. button and see if that's what's happening.
If this advise helped you, please give me a rating so I can make my boss happy! Thanks for using Fixya.com
Jan 27, 2009 | Sony HOME THEATER SYSTEM System
Sony DVD Home Theater System remote control code
I have the same system and one of my dogs got to the remote. I have a philips PMDVR8/PDVR8 universal remote. I was able to get the dav-hdx265 to turn on/off and do volume up and down by using code 0200. I have not been able to get the DVD functionality to work yet, but I will post if I do.
Oct 22, 2008 | Sony DAVHDX265 System
The dvr is not interacting with my tv
:: Remote Control Overview
1 POWER Press to power the DVD+VCR on or off.
2 TRK+/- While a tape is playing, press to manually adjust tracking
(i.e., to remove white lines from the screen).
3 0-9 Use to select channels and set menu items.
4 SKIP/F.ADV Press to skip ahead in one-minute increments, up to 5
minutes, during VCR playback. Press to advance one frame at a time in
Pause mode.
5 SHUTTLE <</>> Press the 4 and 6 buttons to scan forward and
backward at variable speeds.
6 MODE/REPEAT Press to set the Play Mode to Random or Programmed
Play. Also press to set the Repeat Mode to Title, Chapter/
Track, or A/B Repeat (DVD only).
7 ZOOM Press to zoom in at 2 or 4 times normal magnification (DVD
only).
8 100+/3D SOUND Press to select cable channels 100 and above.
Also press to activate the 3D Sound feature, which creates the illusion of
surround sound with only two speakers (DVD only).
9 DVD Press to set the remote control to operate the DVD deck.
10 MUTE Press to turn audio on or off.
11 VOL +/- Press to adjust the volume.
12 STOP J Press to stop playback.
13 REW AA In DVD mode, press to skip to the previous track. In VCR
mode, press to rewind the tape. Press and hold to scan backward during
playback.
14 REC F Press once to start recording in the VCR deck. Press repeatedly
to add recording time in 30-minute increments.
15 ARROW KEYS Y/B/A/" Press to navigate in the menu system, see
page 15.
16 SETUP/ENTER Press to display the DVD+VCR menu system and
confirm menu settings.
17 SP/SLP/TITLE Press to set the VCR record speed to SP (Standard
Play) or SLP (Super Long Play). SLP is three times longer than SP. Also
press to display DVD title menus (for discs with multiple titles only)
May 29, 2008 | GoVideo DVR4300 DVD Player/VCR
Philips 26
There is an input imbalance. Either try connecting your cables to different inputs on your TV, or try connecting to different outputs on your DVD player. (Only worry about the yellow video cable bit initially). Alternatively, try a different cable type; you'll have some ins and outs that don't use RCA connectors.
Mar 03, 2008 | Philips 26PF5521D 26 in. HD-Ready LCD...
Remote Control Control Codes
has anyone solved this problem???
Jan 13, 2008 | Audio Players & Recorders
DVD went in...and won't come out
Whatever you do, DON'T try ejecting it manually. it can ruin the dvd mechanism. The problem is in the dvd power supply. If you have some soldering skills and are good with a soldering iron(temperature controlled is best) you can resolder all the three-legged regulators on the dvd power supply board(small board to the right front of chassis). Good success, Meder's Tv
Feb 20, 2007 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
